Captain Lloyd
I think you've got a Rapido 9090df so may be on the 'light' chassis, if so then you can only go up to 3850kg without modifications/changes.I want to increase my payload can anybody recommend where to go
I recommend a chap called John Ruffles who is less than half the price of SVTech but best to give us more info here about your current vehicle weight, chassis etc so we can advise on what's realistic.
Interesting ... usually up to 3850kg on the light chassis is within it's reach without any mods ... it wasn't the extra 50kg that required the £4,000 changes was it?I asked Conrad Anderson’s who did my self levelling they said I would need new springs on the front and air suspension on the rear said it would be about £4000
Yes your correct I’m on a light chassis I can go up to 3900kg
For 50kg? Why would you bother?
3850 is a paper exercise with no work needed.
Also the AlKo chassis is only tested to 3850 so on top of the £4k of pointless work you’d also need to pay at least the same again on testing to make sure the chassis can cope.
We up rated from 3700kg to the max allowed on a light chassis of 3850kg by fitting rear air assist and bigger tyres, a lot of expense for only 150kg. Though the main reason we did it was to increase the rear axle limit from 2000kg to 2240kg.Sorry my mistake my payload at the moment is 3700k an extra 150k would just enough
Give this guy a call. He's far better value, swift and easy to do.
If you fit air assist to rear and change tyre ratings you can increase rear from 2000 kg to 2240 kg, front stays at 1850 kg but you can’t go over 3850 kg total on light chassis.
You cannot do this with my Bailey ALKO chassis despite having Air Assist - the maximum is 2000kg regardless.
I was told (on the phone by SVTech) this could not be done.You could. The question is whether there's any point.
Have you checked this out with SV Tech, ours is an Alko 2000 and is now rated as 2240 after fitting air assist and bigger tyres.You cannot do this with my Bailey ALKO chassis despite having Air Assist - the maximum is 2000kg regardless.
I would upgrade in an instant if it was possible.
I would advise caution using JR consultancy, as we received wrong advice from him regarding the max weights we could go to, SV Tech, though twice the price, appear far more expert in this regard.
I took my Rapido from 3650 to 4000 with new springs and struts st the front, air assist at the back and higher rates tyres all round. I used SV Tech for the paperwork and Dave Newell for the engineering work. Cost was approx £2000. Details here:
https://www.motorhomefun.co.uk/forum/threads/uprating.179223/#post-2980489
You can if you uprate Tyres and both front and rear suspensionYou can’t. Mel is correct, it’s 3850.
I told my insurance I was going to do it ( tyres, front and rear suspension), then I told them when I’d done it. They were perfectly happy and no change in rates. When they say performance and handling they are only interested in things that make it go faster or handle worse. All of the payload increase work makes it handle much better, and presumably go a bit slower cos of the extra weight!What is the attitude of insurance companies to uprating the chassis above its original design specification (3850)? Not an issue I have any experience of but when discussing other modifications with NFU I was told that they were principally concerned with mods that affected performance and handling. Presumably air suspension and tyre sizes have such an effect. Not looking to be contentious here, just wondering if they nod these things through.
