minesapint
My water pump on our Burstner Nexco. Sometimes will not switch off when the tap is shut down. It seems a relay is staying on but I cannot find the relay. Can anybody guide me to it.
Thanks for your help. I have fliked them a couple of times but the problem persists, I will take a rap apart and put a meter on the switches.There is no relay
I think its going to be the micro switch in one of the taps.
Flick them about to try and determine which one is faulty.
I will trace the pipework and see if I can find it and the controlling relay.If your taps are not fitted with micro switches (look under the tap for electrical wiring going to it , to confirm it is a micro switch type) There may be a pressure switch in the water supply system that switches the pump off and on which needs adjusting , if you can follow the water supply after it leaves the water tank you may be able to find it, it could be beneath a drawer or wardrobe base
Thanks for all the replys to my problem, it now seems to have settled down and is working again. Funny things Motorhomes.My water pump on our Burstner Nexco. Sometimes will not switch off when the tap is shut down. It seems a relay is staying on but I cannot find the relay. Can anybody guide me to it.
