Idiots question (1 Viewer)
Oct 12, 2013
812
899
Filey
N and B Flair
Since 2014
What sort of length of clear hose do we need for filling up the water tanks???, and before someone says it, the answer is NOT ' how long is a piece of string !!!'
MattR
4,104
38,854
Beds
Panel van
Years
Ours is about 5m - not had a problem so far. We have a longer hose but haven't had to use it. If buying, I would be tempted to get 10m and cut it in half and quick release joint so that you have the capacity for 10m but don't have to deal with such a length for the majority of the time.
Mastercamper
578
1,955
Northumberland Flag Flier
Van Conversion
50 years campervanning
How far will you be from a tap?
If you know this, then your question is answered.
Simple really.
daisy mae
675
597
Leicestershire
C class Coachbuilt
I`m a newbie, now 1 year
I bought a flat food grade hose 15mtrs I think on a reel, I only use it at home to fill tank, then use watering can to top up as needed on site, saves hassle of getting to a water tap.
Margaret
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
Get more than you need and cut the hose into two sections clipped together with Hozelock type adapters - that way you can use whatever length you need on the day. Don't buy your hose fittings in a garden centre or B&Q - local markets are often a whole lot cheaper.
Bailey58
8,809
29,529
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
Why clear hose? I have a 7m length of Whale (I think) that connects to the filler unit on the van but carry a variety of Hozelock connectors to extend it with ordinary hosepipe if necessary. If you drink the water from your onboard tank use blue potable hose and try a 5m length with an extra length in reserve to extend it if necessary. :Smile:
Edit: magicsurfbus beat me to it.
TheBig1
17,630
43,266
i have 2x 5m lengths of food grade hose with hoselock fittings on. I also carry a selection of brass connectors, hose end and tap connectors. i usually get away with using just 5m but on occasions have to connect the 2 hoses.
with a brass hose end, i can shut the water off till i reach the tank, plus the weight and size of it holds the hose into the filler port well so i can let go and do other jobs as the tank fills
i wouldnt choose clear food grade hose, as it will discolour and although remain safe it will probably start to look nasty. mine is white marine grade which i picked up locally at under £10 per 5m length
Mar 26, 2009
8,162
11,221
Yr Wyddgrug
Hymer B678DL
Since 2009
I've been using a 3 metre length of food hose for 5 years and haven't failed to fill up. (yet)
Jun 16, 2013
1,228
820
Wiltshire
Low Profile Hymer CL 554
Since May 2014
Where does everyone buy their hose, connectors etc is it from a diy shop or online. Was told i would need a collection of connectors so not sure what to buy.
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
I use blue food grade hose rather than clear. Bought a 30m length that I cut into three sections: 3m, 9m and 18m. All equipped with Hozelock connectors so they can be connected together to form one continuous length if necessary, but more often used separately according to distance from tap. :Smile:
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Since 2009
I bought a reel of 20Mtrs flat hose at dealer where I bought van,and then various connectors from DIY stores and M'sieur Bricolage ::bigsmile:
Mike
TheBig1
17,630
43,266
i have a shop i use locally that sells garden stuff and bankrupt stock. but also bought some more quality fittings from ebay cheaply. dont rely on the cheap chinese plastic copies of hoselock fittings as they crack or wear out quickly. 99p for a chinese one £2.99 for a quality part
could also use B&Q etc as they always have stock
or
Broken Link Removed
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Clear hose is not the best as daylight penetration can promote algal growth in the damp hose. I carry black food-grade hose in two lengths: 5 metres and 15 metres both equipped with push connectors (Hozelock) and a coupling spigot.
Jan 3, 2008
3,339
5,356
Pakefield, Lowestoft, Suffolk, UK
Looking
Hose
Hoselock now do a mini reel with 15 mfrs hose. very compact and easy storage. Its not food grade but I flush it through thoroughly before use and do not think water from it will cause any problems.
Clive
1,296
1,782
Canvey Island
I carry two flat hoses, one a 10mtr the other a 20mtr, also 3 tap connectors, 2 screw on ones of different sizes and a push on one. I have a hose connector as well but never had to use it. The short one is most used but have use the long one a few times on sites to reach distant taps without moving. ::bigsmile:
RS_rob
1,010
669
Turnford
over a Year Yay................
I have a 25mtre blue flat pack hose & a short clear hose for filling next to the tap & on our last outing we needed to fill up so we rolled out both & were a few feet short so had to move the MH so another blue flat roll is needed....
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
You can get food grade hose from a caravan/motorhome dealers accessory shop. The hose we use the most is about 5m and is reinforced water pipe of the type that is widely used for MH internal plumbing. Our is actually red (hot water) as the shop at the time didn't have any blue.
Also have a reel of layflat food grade which is rarely used, and a 2m one for when I'm next to the tap. Also carry a watering can.
wasp
1,724
18,180
Warsop
None gone caravannin
I just use a watering can and it`s good excercise:thumb::thumb::thumb::thumb:
