Idiot Guide to setting up iBoost with micro router (1 Viewer)
Feb 22, 2016
3,613
10,726
York
Bailey 620 Approach
Since 2015
am on a Spanish site and have opened up my iBoost for the first time only there is no instruction leaflet other than a sales flyer. The site only allows one person at a time to log in and so we want to use the IBoost; it's main selling point,
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
Someone will be along to tell you better but go to settings and log on to I boost then go to log in and use mhw and mhw then click on wirelss and select the wifi you want then go to main and see if you have a good signal and then try to open motorhome fun and it should ask you for the password that the campsite gave you and bob is your uncle up to five can log on. Well it works for us!!!!!!!!!
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
Turn I boost on and using wifi connect to it using the password on the back of the unit
In your browser type 10.20.30.40
When asked for username and password type mhw in both
This opens your control panel.
Highlight the wi fi you want to connect to
And connect to it .. click 'change'
Go to a website and if the site wifi needs a password enter it when requested..
Enter password if required
Clive
1,296
1,782
Canvey Island
Ingwe
Feb 22, 2016
3,613
10,726
York
Bailey 620 Approach
Since 2015
I've got as far as adding mwh in both user name and password. However the quote above has flummoxed us. We don't see a wifi that we can connect to just a lot of info about iBoost. Have we missed a step?
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
Yes go to second heading across top that say wireless and click that and then ask again
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
I'm trying to remember...
So if you entered user and passage your into the unit....you need to select the second tab along.. wireless or networks it's called. . Thats the page you select what you want connect to And select change.
andy63
4,672
15,017
south shields
None
since 1990
Hi I'll add a little more detail to the above explication. ..
Just in case you need it..
Once into the router log in pick wireless at the top of page.
On that screen labeled wireless setings press the select button.
You will get a list of available networks...
Select the one you want by ticking the dot on the left of list.
Press select at bottom of the page.
That network will now be displayed and if a pw is required enter it
Then press change at bottom of page.
A blue bar will appear asking you to apply the changes so press apply...
At that point give it a minute then select main at the top of the page.
On that page you will see the details of the network you are connected to... the signal strength and the tx/rx rates..
There must be figures appearing in both tx and rx..rates..
If there isn't then regardless of signal indicator you art connected...
Hope that helps.. it takes a bit of playing around at first but it eventually becomes easier ..
Andy.
Ingwe
Feb 22, 2016
3,613
10,726
York
Bailey 620 Approach
Since 2015
Thank you all for the detailed advice offered and to Clive for troubling to scan in and attach the printed instructions.
Everything working now.
Thanks again all.
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
1 Have you connected the Ethernet cable?
It goes into ETH2 on the router?
Sounds obvious but some times .....
Edit, Sorry I see it is fixed
Selby Spicer
Evening everyone, I've read all the instructions and ensured the unit is wired as it should; however, after I get to the log in screen and enter the user name and password (mhw) I get the message invalid credentials... Can anyone assist?
Many thanks.
Stonemags76
1,280
3,994
Derbyshire Dales
Auto Sleepers Warwick Duo
Full Time 2011-2013, now part timers!
Have you been into your device settings and joined the iboost network, using the password on the back of the iboost?
