Have seen that you can get some UK TV channels using an IcecryptS1600 and tuning into Intelsat 907,can you also use the S1700?
According to Amazon seller https://www.ama zon.co.uk/S1700-Icecrypt-S1700CHD/dp/B00LX3U008/ref=sr_1_1?s=home-theater&ie=UTF8&qid=1503378521&sr=1-1 you can enter BISS codes so would assume this allows access to Intelsat 907. (Broken Link Removed)Thanks @ambulancekidd ,I have read that and more. Another fun member has bought the s1700 as it is faster and has more functions,just not sure if you can decrypt this one as all the info seems to say the s1600 does the job.
Who is actually going to come round to your camper and check if you are watching tv from the Intelsat satellite bearing in mind you are only watching freely available tv channels not a subscribable service?Just remember it is illegal and you could get fined, heafty if they wish to make an example of you, and the equipment can be confiscated, awkward if it is bonded to your motorhome and they take that.
Also bear in mind that this service was due to be turned off some time ago, but is still available and that the BISS codes can change at the drop of a hat
I understand what people do it, I just think that some that sell the equipment underestimate the potential legal risks, technical problems should the codes be changed and the fact it is well past its turn off date.
You can tell at a glance as the satellite points a different direction.Who is actually going to come round to your camper and check if you are watching tv from the Intelsat satellite bearing in mind you are only watching freely available tv channels not a subscribable service?
If they were that bothered about it why did they use biss encryption the weakest of them all?
Biss codes haven't changed in two years
The last Intelsat satellite lasted nearly 7 years past its decommission date. Just saying
Just called,they are busy.Will call back shortly.Why not give them a ring and ask them.?
Got the autoskew model.Trust me the S1600CHD se model works fine as well.
Other considerations are that you need a 85cm Oyster Autoskew for it to work well further South.
Autoskew or you will physically have to rotate (skew) the LNB about the same amount in the other direction that is required for ASTRA 2.
BBC SKY ITV et al only buy the UK rights for films and sports. There is no point them paying millions extra to beam it in English across Europe, for a handful of holiday makers to watch. Anything good home grown, they in turn sell on to the European broadcasters, suitable dubbed or sub titled.I just don't understand this copyright thingy, how is it that all the people in Europe can see the channels back home- Germans in Spain, French in Germany and all the others - but the English have this copyright thing and say- oh no not allowed old boy- why oh why are the English missing out AGAIN?
I've never heard that, and given the technical and legal issues it would be hard.I may be mistaken but I thought the the EU Commission said that all EU citizens should be able to receive the programs from native countries.
Just saying
Bear in mind that your not even allowed to watch normal TV in your motorhome unless you have a licence in your home, and you have signed a declaration to state that when your away in your motorhome/caravan that no one at home will simultaneously be watching TV! No one does of course but we are all meant to and the links and PDF's are all there to be followed.
I blame Sky and early Sky customers. Had Sky chosen to use Astra 19.2 as does most of Europe, Sky FTA Freesat etc would be available across Europe and the legal eagles would have written the contracts accordingly. Money control and encryption drove him to Astra 28.2 and its annoyingly small footprint
You don't have to have Autoskew, just add a second LNB and a DiSEqC switch, works fine. Don't forget you may not have Intelsat to choose from So search for HispaSat with the second LNB then go to manual with a meter on screen and go about three clicks left and two clicks up to get the best signal. It will then return to the same place each day if you don't move the van. You will need to program the switch into the box of course to switch between LNB's automatically.Trust me the S1600CHD se model works fine as well.
Sky's German service is a German subscription service for German residence it isn't the UK Sky simply beamed into Germany.But Sky have started a service in Germany and are thinking of starting in Spain over the internet.......I thought I read, so how does that fit the contracts? Just wondering
learning Spanish sounds easier LOLYou don't have to have Autoskew, just add a second LNB and a DiSEqC switch, works fine. Don't forget you may not have Intelsat to choose from So search for HispaSat with the second LNB then go to manual with a meter on screen and go about three clicks left and two clicks up to get the best signal. It will then return to the same place each day if you don't move the van. You will need to program the switch into the box of course to switch between LNB's automatically.
All totally theoretical of course nobody would ever dream of watching something that Auntie Beeb would not like you to would they?
Steve
It's a good system isn't it Steve? See you in manta rotaYou don't have to have Autoskew, just add a second LNB and a DiSEqC switch, works fine. Don't forget you may not have Intelsat to choose from So search for HispaSat with the second LNB then go to manual with a meter on screen and go about three clicks left and two clicks up to get the best signal. It will then return to the same place each day if you don't move the van. You will need to program the switch into the box of course to switch between LNB's automatically.
Steve
That's going to be great with Satellite internet. One episode of Neighbors and your months allowance is gone.It is all academic as we will all be watching TV over the internet soon with a pay per view system automatically debiting what we watch from our banks
I reckon ten years tops as a guess
Yes Sean,It's a good system isn't it Steve? See you in manta rota
I agree DiSEqC is extremly simple a fool can do itUnfortunately my mind is wired to understand how to program a DiSEqC switch rather than learn Spanish.
I just don't understand this copyright thingy, how is it that all the people in Europe can see the channels back home- Germans in Spain, French in Germany and all the others - but the English have this copyright thing and say- oh no not allowed old boy- why oh why are the English missing out AGAIN? I may be mistaken but I thought the the EU Commission said that all EU citizens should be able to receive the programs from native countries.
Just saying
Because they will only show content that they have the rights to for Spain...of which most of the content that Sky UK show will be tied down to other broadcasters and providers and so will not be available on this internet service.and are thinking of starting in Spain over the internet.......I thought I read, so how does that fit the contracts? Just wondering
Most French channels are encrypted on satellite and require a viewing card sent to a French address to view...as are Spanish TV channels...so there is some "locking" of channel even if the signals are freely available...
EU have said nothing of the sort...IIRC it was that all EU citizens are required to have access to news and events in their own language across the EU. For the UK BBC World News (and Sky News) provide this, and is why every country has a few free to air news channels available across Europe...it does not mean ALL channels needs to be accessed by all.
That's a little harsh Eddie, some people don't even know what it is, let alone how to use it, I wouldn't call hem fools. By the same token I my brain is not wired for languages and I don't expect to be ridiculed for it. Everybody is different. I have a friend who is fluent in about five languages but asks me how to use or fix his computer. Which to me is so simple that " any fool should be able to do it ".I agree DiSEqC is extremly simple a fool can do it
But your stance on Intelsat I totally agree with. I wouldn't expect you to install, recommend or even condone the use of it. It's a hobbyist thing if you understand the risks, have the ability to do it and are prepared to take the risk then like speeding or overloading a Motorhome that is up to the individual.
