Iminstalled twin cameras, one for the rearward view of the road and the other looking down at the ground below.Has not stopped me backing into things thoughcould you weld the railing/balcony back together (assuming its a metal railing of course)?
-- sorry, couldnt resist
as a temp fix have you considered expanding foam? though it would also prob set hard enough and be flexible enough to carry out a fibreglass/resin patch over it.
a lot of work afterwards sanding etc and you could get a really good DIY repair - or could you put some sort of deval over the repaired area to hide it?
i feel your pain, all reversing cameras concentrate on the bottom of the vehicle - overhanging obstructions can be just as bad or someone helping/watching you back doesnt look up
we also have a proximity sensor at the back, which i rely on more than the camera BUT it doesnt warn of high hazards either - perhaps that is something manufacturers should consider fitting .....Iminstalled twin cameras, one for the rearward view of the road and the other looking down at the ground below.Has not stopped me backing into things though
From the balconyI backed my Comanche into a balcony and the railing punched a hole in the fibreglass just below roof level, what's the best way to repair it ?
Yebbut, has..... horse....after.......bolted.....the...........door........ stable..........the............ shutting......has.....we also have a proximity sensor at the back, which i rely on more than the camera BUT it doesnt warn of high hazards either - perhaps that is something manufacturers should consider fitting .....
That's an outstanding idea.From the balcony
If it wasn't outstanding you would have missed it.That's an outstanding idea.
Brilliant , I laughed out loud when I read this.From the balcony
Not half as much as i did when I first read the original post. (Shouldnt laugh, I've managed to rip a campsite reception gutter off before and all my van needed was a high level reflector to cover the gouge.Brilliant , I laughed out loud when I read this.
