I have more questions for the lovely helpful and knowledgeable people on here. I have a Hymer B584 2002 with Truma gas heating (Also electric for hot water but that is not relevant). The control says Trumatic C and has a circular dial for temperature control. It is on the outside wall of the wardrobe, and the boiler is inside the lower part of the wardrobe.
1. Where is the sensor? I can't find one, it is not above the door as someone said on another thread. Is it perhaps integral to the control?
2. It only heats up to about 7 degrees less than the figure on the control, even if it is not too cold outside (so it is not struggling to heat, it just thinks the job is done when it is not). If the sensor is inside the control that would explain it (the wardrobe is warm), and I would like to install a separate sensor. Is that easy?
3. At about 0 degrees C outside (clear sky but sheltered from wind) it will only heat up to 19 degrees or so, going continuously. Is this to be expected, or is is a sign that I need to get it serviced? The vents do blow warm air, but very gently.
4. Is there a way to add another sensor "in parallel", i.e. heating comes on if either sensor says so. Reason: the gas heating warms up underfloor and so keeps the water system warm; if I am on EHU with a heater in the habitation area, that won't happen. Or is there a sensible idea for keeping underfloor warm?
