Hymer MLt whip TV aerial wiring
Hymer ML-t 580 4x4
Getting there!
I am fitting a second TV into the bedroom area. I have a twin LNB and satellite cable to the location of the new TV.
I'm just wondering about how easy it would be to connect the new TV to the existing terrestrial aerial. It's not essential but while I'm wiring up, if I can tap the aerial it's a fairly easy cable run to the new TV.
Anyone know whether the whip aerial has two outputs ?
The amplifier they use may well have as a 2nd TV is an option.
Have you checked behind the bedroom lockers to see if there is a cable there. Another place they coil up and hide cables is behind the kitchen draws.
Couldn't find anything behind the bedroom cupboards. Under the kitchen drawer might be a good shout as it's close to, and on the right side of the van for the bedroom TV fitting place.
.... or just fit a different bracket that permits you to turn it 180 degrees, so you can watch from either end of the accommodation space.
other option is just velcro an iPad on the bulkhead.
