Hymer Front Light replacement (1 Viewer)
Feb 16, 2020
227
328
Taunton
Hi guys, broken front light. Stone thrown up by a lorry so unlucky. See photo. First day on the first real trip that was not a weekend having just retired but apparently things don’t stop going wrong just because you are retired!
MOT due so I need to get this sorted. Does any one know is these are easy to fit and where to buy one?
Jun 8, 2019
4,931
18,760
Bexley Kent
Given up Motorhoming
May 2019
Sorry to hear about your misfortune.
Lenny web along any minute now.👍🏼
Jun 12, 2016
1,621
4,356
Scottish Borders
Globecar Revolution
A funsters has manage to make replacement lenses for some
Sorry can't remember of hand their name
A serch on Hymer lights should find it
Nov 17, 2012
1,930
2,614
WEST SUSSEX
HYMER B SL 674
SINCE 2005
Thanks in anticipation.View attachment 492650
Unfortunately a few weeks wait and approx £900 inc of vat. Try Reliance in Chichester.
Feb 24, 2013
13,083
101,448
Bolsover, Derbyshire
Hymer S800
not long enough
Or £1500 + if it’s got washers and Bixenon bulbs 🙁
but we also used Reliance for our second one, supply only
would not recommend letting the major midlands Hymer dealer anywhere near it 🤔
Feb 24, 2013
13,083
101,448
Hymer S800
not long enough
Fitting is critical, I had my second one done by a car repairer friend who said the tensioning was critical
but not difficult to get out, I did that but myself 😁👍
you need to use slightly more force than you might like to getting it off a ball joint type fixing 👍 but as broken already it couldn’t break anymore 😁
Jul 6, 2016
1,547
1,264
West Sussex
Carthago Chic A clas
Since 1990
GWAYGWAY may be able to help.
Feb 22, 2008
12,265
45,049
Nearly Tugging
I know it’s a bit late for you but following the previous threads on shattered headlights and the cost I bought a pair of Perspex protectors and only remove them for cleaning.
Feb 24, 2013
13,083
101,448
Hymer S800
not long enough
I did the same but lost one fairly early on 🙁
then bought a small sheet of LamX stuck that on some years ago following second breakage
not sure if now an early design fault has been fixed, now fitted properly or the film has saved them
not good for OP but slightly reassuring to see it was probably a stone and offside damage not the usual parked up nearside 🤔👍
Feb 22, 2008
12,265
45,049
Nearly Tugging
It’s the use of tempered glass that is a bad design , just as with windscreens on old cars used to shatter.
Rodders1234
Feb 16, 2020
227
328
Taunton
Hi Larry, where did you get the perspex protectors, these look good?
A while ago I did see some protecters on ebay, they were expensive but from the comments about the cost of glass light replacement I can now see why you would buy them!
Any other suggestions welcome. Thanks
Feb 22, 2008
12,265
45,049
Nearly Tugging
I got mine on EBay also £75 , damned expensive but I realised it was at the time the only quick option. They come as flat Perspex and I used a heat gun to bend them to follow the slight convex shape of the headlights and also found some chrome caps to enhance the plastic fittings.
It would I’m sure be easy to get a small sheet of perhaps 3mm Perspex online or possibly B&Q and cut them yourself .
I recently replaced the 52mm suction pads a pack of 4 for £6.49 (2 packs required) from Amazon.
So the job needn’t be too expensive if you are handy with your hands.
53,426
149,964
My last van had the same headlamps, I made my own protectors from 2mm Polycarbonate.
Rodders1234
Feb 16, 2020
227
328
Taunton
£990 down and the light is over 2 weeks late coming form Germany. MOT due yesterday so had to cancel next week trip and loose deposit!
Protectors due to arrive Monday, just wish I realised how expensive the lights were to replace and I would have bought the protectors earlier. Hindsight is a wonderful thing. Thank you for your advice.
Met a guy on a site in Norfolk who had the same problem, he sent the original damged light back to Hella and it was from a faulty batch they refunded him his money. As mine are 6 years old I don’t think I would be so lucky.
Interestingly he now had a later MH but with the same lights and although he also told me about the protectors he was not using them!
