- Oct 10, 2014
- 312
- 294
- Hymer B680 Starline
- We are no longer Newbie's.
My engine battery does not appear to be charging from solar which ended up with a totally discharged battery last winter whilst stored. The van is a 2000 year Hymer B680 Starline with an Electroblock 99 and 100W solar panel. There is also a Battery Master fitted but the light on it never comes on. I have measured the solar panel input to the regulator at 18V and the output to leisure batteries at 13.8v so that side is ok I believe, and the leisure batteries remain stable at 13.8v most of the time but the engine battery is falling slowly and is currently at 12.4v. Both leisure batteries were renewed last year and the engine battery this spring so I have no doubt about their conditions. Both batteries charge ok when the engine is running but I haven't been able to check when on EHU.
I thought that the solar was supposed to divert to the engine battery when the leisure batteries were fully charged through the electroblock but maybe that is wrong and possibly why a previous owner fitted a battery master to do that. I am not sure how these are wired up whether through the electroblock or straight between batteries so it is a bit difficult to work things out. I am sure the battery master light used to come on when I got the van but not now, so maybe that is broken or a fuse has gone somewhere. Can anybody help me out with a fault finding way ahead? @Jean-luc maybe? Can I pull fuses to check and replace them on the electroblock without switching it off first?
