Hymer dash board clips (1 Viewer)
Steve and Denise
5,291
14,086
Spalding LINCS
A Class Carthago
Since 2008
can anyone tell me is there a way of removing the caps of these fittings without destroying them it seems you have to take out the cover to access the screw inside.
I have tried strong tape and even tried glueing something to it failing that I will have to prize it out to get to the screws.
Nov 4, 2011
5,939
38,915
Uk
If you mean this type
you put a screwdriver under the edge and they pop off.
There's a plastic washer under the screw with a lip that the caps clip onto.
Oct 9, 2017
429
1,052
Wisbech
2007 Hymer B654
I suspect he is talking about the “top hat” type with a flat (thin) round rim. First time I tried to prise off the whole thing and broke the rim part. Then tried to prise out the centre part using the point of a Stanley blade but still no joy. Gave up in the end.
Will be interested in a successful reply.
David.
Oct 9, 2017
429
1,052
Wisbech
2007 Hymer B654
Since my reply I see you have posted a picture. That’s the type I was referring to, however, on mine the centre piece protrudes up from the flat bit (rim). Your centre piece is pushed in more, which would make it even harder to remove.
David.
Ps. I notice you are in Spalding also! We are located near to Rugby Club.
Steve and Denise
Steve and Denise
5,291
14,086
Spalding LINCS
A Class Carthago
Since 2008
@dalspa the only way I can see is to drill a small hole and put in a screw and pull it out giving access to the screw inside Holbeach in reply to location.
43,323
49,440
A long shot.......
The screw head may have a threaded hole and the cap screws into it.
Usually the cap is domed, chrome and secures mirrors to walls but the principle is the same.
Lay a rubber band over the cap, press down and turn anti clockwise.
Nowt to lose but a minute of your time.
Jul 29, 2013
9,071
18,518
Salisbury
Hymer B678DL A class
since 2011
I don’t think there is a screw beneath it from memory they are a plastic peg type that’s push fits as the spigot is sort of sprung all I know is they are very hard to get out.
Lenny HB
53,420
149,939
On the coast in West Sussex
Hymer B678 DL
Afraid they are a one shot device but easy to obtain from motor factor or eBay search "wheel arch rivits" or "Trim panel rivets".
Lenny HB
53,420
149,939
Hymer B678 DL
That surprised me, if you can't get replacements easy (Hymer dealer should have then if you can afford it) you could fill and paint any you wrecked getting them out.
Nov 4, 2011
5,939
38,915
Uk
Could the centre be prised out with a small penknife blade.
Jan 1, 2019
758
1,424
Pembrokeshire
Hymer B704 PL
Since 2017
Hi Steve and Denise,
I need four of these fasteners. Can I ask whether you ever found a supplier?
Toady
Jan 31, 2016
1,902
3,377
Alness, Cromarty Firth
Hymer B544 (2012)
newbie
On my Hymer, they have a 1mm hole drilled in side/edge of the inner flat top, I then poke a needle in and the inner disc pops off. I would like a couple of new ones in black but never managed to find any yet.
Steve and Denise
Steve and Denise
5,291
14,086
Spalding LINCS
A Class Carthago
Since 2008
Toady
Yes. I bought a pack of ten in white for our shower exactly the same except the colour Chris @ Reliance got them for me but you could try Brownhills as they used to be good for Hymer stuff although rubbish for most other things đź‘Ť
Jan 1, 2019
758
1,424
Pembrokeshire
Hymer B704 PL
Since 2017
Thank you Steve and Denise. I contacted Chris at reliance and he had a pack of ten clips of the exact size. Hymer dash looking tidy now. Thanks again.
RM_Marine
674
1,157
Poole, UK
Autotrail Apache 700
Since 2021
Same things hold the plastic surrounds on the autotrail front sky light and was wondering where is could get them from 🙄
Jan 1, 2019
758
1,424
Pembrokeshire
Hymer B704 PL
Since 2017
Chris at Reliance
Not cheap. I ordered a pack of ten and with delivery ÂŁ24. The dash looks finished mind which is what I wanted so worth the price.
Jan 8, 2013
8,490
11,527
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
I like the idea if a small hole and extractor screw. Ill try it next time.
These are my type
