Róbert_IS
- Sep 13, 2017
- 4
- 4
Hello. I recently bought a used Hymer 542 CL. It has a Trumatic C6002 boiler/heater.
Q1: When opening a water faucet, e.g. in the kitchen, the water pump starts and the water pours out of the faucet like it should. At the same time the fresh water gets dumped via a pipe that´s just beside the left rear wheal of the vehicle (see attached pic). When turning off the faucet, the fresh water still flows out of the pipe, even if the water pump has stopped. This means an empty fresh water tank within a short period of time. I have checked the red drain valve beside the boiler and it is closed and also the temperature is well above 4°C.
Q2: On the other attached pic. there can be seen two blue valves, one is connected to a red hose and the other to a grey hose. What is the purpose of these valves? Should they always stay open? When should they be closed?
