Hymer 12V grey waste
Alan and Kate
Hymer B598PL
Help. I own a Hymer B598PL 2015. The 12V grey waste solenoid valve is not closing with the switch and making a clicking noise when switched on. I have sent pictures to a motorhome dealer of the solenoid valve, they have quoted £441.00 for a replacement! Please advice best options, picture attached.
Cabbunk Central
Carado T459
Not long enough!
Hi, if it was working fine before, before replacing it, make sure that the pipe and valve are clean. If there is debris trapped in the area where the solenoid closes, it may just provide too much resistance and click. Good luck.
Lenny HB
On the coast in West Sussex
Carthago Compactline
The Lilie one is about €130 but no one in the UK sells it.
That Sargent ones looks identical but you may find the valve is 28mm rather than 40mm that Hymer use.
Ring them & find out, you might want to ask them if is the same as the Lilie one.
If the valve is 28mm you should be able to just swap the solenoid over.
