Hydrogen injection any use?
Minxy Girl
26,078
42,452
E Yorks
Carthago Cmpct i-138
Since 1996 we've had Elddis, Swift, Rapido, Rimor, Chausson MHs and Autocruise & Globecar PVCs
funflair
15,268
20,237
Guisborough
MORELO palace
since 2012
Not sure what you're trying to show us but I can't see anything but a general MH group info ...
Its a,
DIY CELL HHO HYDROGEN GENERATOR 11 PLATE MINI EXSTREME IDEAL FOR SMALL 4 X 4
HHO GENERATOR DIESEL OR PETROL UP TO 3.0 LITRE
YOU ARE BIDDING ON A SELF ASSEMBLED 11 PLATE HHO VERSION SS 13 DRY CELL.
"NO MORE CORROSION"
This HHO cell is all 316 stainles steel, bolts plates, everthing is stainless except the acrylic end plates and base mounts.
MAXIMUS MINI EXSTREME 11 Version 13 Series is our latest cell design, Push in quick release 90 degree brass swivel fittings makes this unit a breeze to fit and you can add more cells quickly without fuss. Quick release metal fittings all the way from cell to engine. With bigger outlets and bigger bubbler. Included is the latest PRO 30 CCPM 12 or 24 volt Also included is the latest poly spun dryer and additional electrolyte trap with brass sintered filter. Enough HHO for up to a 3 litre diesel or petrol engine and is able to have more cells added where needed. Ideal for four wheel drivers with the combo filter for those up and down situations.
SET INCLUDES
Maximus 11 Plate V13 Dry cell with quick release fittings ( needs to be assembled)
Pro E30 CCPWM Intelligent CCPWM , with amp gauge
2400 PE tube to fit quick release fittings
Purpose built HHO 1 litre Bubbler tank
1 X Combo filter trap and gas dryer trap with sintered filter and manual drain
1 X 1/4 Check valve, Self Tapping Mount Screws
1 X 30amp waterproof fuse 1 X 60 AMP RELAY
All electrical tabs and fittings needed
Please note: We do not include the wire . Suggested size 6mm auto wire for small 11 and 21 plate and 12mm for Brutus and twin cell systems. Wire size is relevant to distance from source and amp draw.
ADDED BONUS
All our Version SS cells are pre-treated with anti foam agent so you always get off to a good start.
All our cells are pressure tested and checked for Continuity.
Once connected to the bubbler and vaporizer this Cell is ready to go just add electrolyte and power up!
Jul 29, 2007
5,736
23,819
Ipswich
RV and PVC
30 years
I assume this is one of those systems that uses your cars 12v to split water in to hydrogen and oxygen.
So you burn petrol at 30% efficiency to create 12v at your alternator, you then use that to electrolise water at another 30% efficiency, pipe it in to your inlet manifold and hey presto, your doing twice as much to the gallon.
Sound too good to be true? Your right.
Snowbird
11,813
22,075
Liverpool.
Fifth wheel.
Since 11-05-2000
These kits have been around in one form or another for donkeys years. They have been proven many times to be of little or no benefit. The only way I know of running a diesel engine more cheaply than pump diesel is bio diesel or black diesel from waste oil. Whichever of these systems anyone chooses depends on the type of injection system and engine. Also a considerable amount of study, outlay and time is required to make it viable.
Aug 6, 2013
10,980
13,994
Kendal, Cumbria
since 1999
Whilst l agree that HHO systems are likely to be snake oil l can't help thinking that there must be some way to burn the particulate carbon wasted by the Diesel engine. So far attempts to remove it from the exhaust involve burning it outside the engine in the particulate filter where it contibutes nothing to power or economy. It is likely that LPG injection is successful (in Diesels) because it helps in that area. It might be possible to use HHO to do the same.
Dec 12, 2010
4,027
12,920
Cumbria
since 2011
I did hear an old wives tale that unscrupulous truckers would sit an lpg bottle in the cab with a pipe running to the air filter and crack it open for some rudimentary boost.
Snowbird
11,813
22,075
Liverpool.
Fifth wheel.
Since 11-05-2000
No such thing as an unscrupulous trucker, they are all pillars of society :cool:.
Steve N Tracy
940
4,011
Southampton
4 Years
I saw my first one of these sort of things fitted to Ford Corsair in the 70,s they did not work well then and if they worked well now we would all have them.
