Leave down to take weight off the tyres when not using the Motorhome?
Downsides?
Downsides?
I just take the weight of the front coil springs, to stop them compacting slightly over time.
Its hydraulics you can top it up and they should work.Like the idea but, met a chap at Nec. said a pipe leaked could not get Jacks up , don't too much about this system, but if that happens you can't move the vehicle , Supplying Company did not operate breakdown help, apparently said you will have to get a breakdown Company to help you,
my van has a front cross spring and it has just cost about £900 to fit a booster spring to lift it off the bumpstopsWhy just the front?
Ian
Over the years, I have replaced an awful lot more sagging leaf springs than coil overs !I just take the weight of the front coil springs, to stop them compacting slightly over time.
You can lift the jacks manually using a battery drill to spin the pump motor.Like the idea but, met a chap at Nec. said a pipe leaked could not get Jacks up , don't too much about this system, but if that happens you can't move the vehicle , Supplying Company did not operate breakdown help, apparently said you will have to get a breakdown Company to help you,
