Hve i enough guts? Inverter (1 Viewer)
Mar 21, 2010
2,486
2,993
I HAVE A PURE 500 INVERTER. Travelling I normally connect one of our electric bike batteries to my inverter. A journey of over 180 MILES + But does not have enough guts to charge the battery ?.
Suggestions please.
colyboy
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
I don't think you're travelling far enough! :)
Charge for longer.
How long does it take to recharge at home/on mains?
dabhand
4,307
23,935
Staffs
Concorde carver E35
Since 1993
If you divide the amp hour rating of your battery by the amp rating of your charger, that is how long it will take you to fully charge your battery. However, all good lithium smart chargers dial back the charge at the end of the charge cycle, so they take a little longer than what they are rated for. So for a 10 Amp-hour battery it will take a 5-amp charger a little more than 2 hours to charge your pack. With a 1-amp charger it will take 10 hours. The larger the battery, the safer it is to charge at high amps. For example, charging at 5 amps is fast for a 10 Amp-hour battery, but…not so fast for a 20 Amp-hour battery. When you charge your battery fast, all the time it will greatly reduce your batteries life expectancy. Its recommended you stick to slow charging (4 hours or more)
dabhand
4,307
23,935
Staffs
Concorde carver E35
Since 1993
Ohms law would measure the inverter output at about 2 amps btw
scotjimland
2,309
9,979
A Woosh bang
just to clarify, it's not ohms law.. which is the relationship between amps, volts and resistance
Electrical power is measured in watts = volts x amps
∴ watts/volts = amps
500/240 = 2.08 amps
@colyboy to answer your question , a 500watt inverter is more than adequate for the charger, measure the time it takes at home to fully charge and it will be the same time required when driving.
dabhand
4,307
23,935
Staffs
Concorde carver E35
Since 1993
You are of course correct, however the above was for the sake of brevity and arrived at the same answer, the majority of equations and laws for analyzing circuits can be derived directly from Ohm’s Law. By knowing this simple law, you understand the concept that is the basis for the analysis of any electrical circuit! An ohms law calculator would be used to give the above calculation.
Lenny HB
53,417
149,914
On the coast in West Sussex
Hymer B678 DL
500 watts is more than enough for one battery most bike chargers are 1 to 1.6 amps at 230v. Our Bosch ones are rated at 1.6 amps max takes over 3 hours to charge a 400 watt battery. A lot of chargers are lower power so can take 4 to 6 hours to charge the battery.
Edit:
Have you checked the inverter hasn't triped out as if the charger has not been used for a while the switch mode supplies they use in they can draw a high start up current and trip out the inverter.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Suggestions please.
colyboy
Find the battery spec in terms of Amp Hours ( Ah ) often 10Ah.
Find the charger spec for Output ( usually 2A ).
In this case 10 / 2 = 5 hours no matter what you plug the charger into.
e-bikes are tricky things to live with when off hook. Ideally you'd charge them when the sun shines, just when you want to be riding them.
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Look at the Spec; for the Inverter. Some give the Input power, and others the output. As with all "converters" there will be losses. You may not be getting a 500W output.?
