Hullo and help 😄
colinmcneill
Kontiki 615
Hi everyone. I was wondering if any of you lovely people could help me. I'm looking at a new 12 volt TV but my existing TV is set up per the attached pictures with a scart lead into my easifind digital. If I purchase the new TV it has an HDMI cable and no scart socket on it.
Is there a quick way or a newer easifind digital that will leave all the setup the same and connect the new TV.
Thanks so much in advance 🤗
I assume that box is to give you digital Freeview TV? Newer TVs will have the Freeview decoder built in, just connect the aerial.
Hi Guigsy.
Thanks so much for replying. This box is for my satellite dome on the roof. It's a cosmos. Would that still be the case
You can get a Scart to HDMI converter cable, Ebay or Amazon around £5.00
Thank you. Does this have to be a powered one as I don't have a socket to put the usb end in. Sorry totally clueless 😅
Hi Guigsy.
Can you get a FreeSat TV? I don't know if it's the same frequencies as you're using now?
Also, a lot of TVs have a USB socket on the back to power dongles. So that SCART adapter might still be ok. But you'd get a better picture and less points of failure and less remotes if you could bypass the old analogue stuff.
Also it's this type of scart thanks
You need a scart to hdmi converter like the one below. Your existing scart cable that used to go to the TV goes into one end and a new hdmi cable would fit from the other end to the new tv. It will require a USB power supply, quite often the TV will have a usb socket which will power this.
You might be better getting a TV with a built in satelite decoder, unless that box also controls the dish somehow. SCART is a 1980s abomination compared with modern digital systems and offers very low resolution with analogue artifacts on the screen (you'll still get the digital ones as it will be converted to/from digital at both ends).
....or even a cheap Freesat decoder, like the Manhattan SX .....?
Broken Link Removed
Then plug the LNB feed into the SX and use an HDMI lead to the new tv....
I think that one needs a 230v power supply? (Post #16)
No - it runs off a 12v dc supply too.....
Also, I forgot to say that it comes with an analogue RCA lead and scart adapter as well! (y)
