- Jan 3, 2008
- 3,410
- 5,511
- Autosleeper Warwick
That’s what I use, powered through one of theseI use a 5577 mifi, and it gives better speeds than my mobile. I’m in the process of fitting an Huawei 4G router - 535-232 - which gives even better speeds with a decent antenna.
I your asking about the one in my post, it gives power to my router set at 12 volts, rather than the 13.5 volts the van is and also has a USB port on itIn simple terms please what does that device do?
Huawei are a pain for making lots of different versions of the same device, but without changing the name. Some e5577 have antenna connections, some don't.I have an e5577 that is next to useless. It came with a pair of antenna but has no where to plug them in. Can anyone suggest something decent around the 100 pound mark?
As said by others you need to be careful on the sub-model you order as the e5577 has a few.I have an e5577 that is next to useless. It came with a pair of antenna but has no where to plug them in. Can anyone suggest something decent around the 100 pound mark?
