How to test a split charge system.? (1 Viewer)
Chris51
Mar 24, 2010
1,073
766
stoke on trent
relay lwb pvc
6 years
Easiest way..... check the battery voltage..
Start the engine and check again
If its working it will go up :)
Doesn't go up when engine started and revved ..solar is charging OK reads about 13.2.Will check to see if wire loose.
Apr 27, 2016
6,933
8,098
Manchester
A class Hymer
Since the 80s
It's a good idea to check the starter battery voltage as well. If its voltage goes up when the engine is running then at least you know the alternator is charging OK.
TheBig1
17,666
43,560
check the voltage at the split charge relay output with the engine running
TheBig1
17,666
43,560
That will/should be the same as at the leisure battery.
Leisure battery is easier to find.
yes the leisure battery is easier to find but no power from the relay can be traced back etc
43,425
50,204
Agreed, but as the OP is asking how to check so his knowledge of 12v electrics is limited, he may not know what to look for when identifying a relay.
Plan of actions
No power at battery > check relay output, no power > check relay input, no power > check battery to relay fuse then battery connection.
