Well, I'd got that far....... So, it's not standard? I'll just have to experiment?They are the protection for individual circuits. Same as domestic supplies.
Yes, it is standard.Well, I'd got that far....... So, it's not standard? I'll just have to experiment?
Thanks to everyone for the useful info. I plan to take 10 minutes to check what each MCB is isolating and label them......Yes, it is standard.
As said, one will be sockets and maybe charger and one for fridge/boiler etc
Unless you're working on a circuit, in which case it needs turning off, it doesn't matter which does what.
Why the installers can take a few minutes to label them is a mystery.
If there's an overload fault one will trip while the other won't.
There needs to be a single switch to shut off all 240V power. If all the power goes through the RCD first, then to the MCBs, then switching off the RCD will turn off the whole 240V supply. So no need for an extra main switch.Anyway, my set up, standard CBE has a test button (yes it works OK) and 2 breakers, i assume the 13 amp sockets are on one and the other is for the fridge and/or anything else needing to be isolated. So no breaker for the entire setup, probably assumed that whichever Circuit is overloaded it will "break".
