How to get hot water
Benemar
The water heater is hot but no hot water coming through taps. Help please
Truma water heater, beneimar 202
You say the water heater is hot, is there water in the boiler?
Is the infamous Truma dump valve closed? Have you recently refilled the van with water after a layup?
Do you have a Truma boiler for heating and hot water? If yes have you turned the boiler on, and not just the heating?
I take it you've filled the fresh water tank and primed the system with water coming out of the taps,can you hear the pump running when you open a tap?
Was it cold where you were last night? If the temperature was down to 3 or 4 deg, or less the boiler has probably activated it's self preservation water dump function, so there's no water left in the system.
Mike.
Can you clarify that? Do you mean the water is coming through the hot tap, but it it cold? Or there is no water coming through the hot tap, but there is water coming through the cold tap?
I think they may be allowing the boiler a generous time to warm up, ;).
Mike.
Microswitch in the tap failed?
