HKF
- Jul 18, 2021
- 2,144
- 4,398
- Benimar Europe 740
- Since August 2021
Hi everyone I recently posted to ask how to drain the boiler in my Benimar Europe 740. After receiving lots of helpful replies but being unable to locate the boiler, I emailed the previous (French) owner and received this reply;
"As for the cold nights and the water heater, no worries either: the safety system is automatic: It empties itself when the outside temperature is less than 5°C. The only condition is that the battery of the camping car is not empty for the thermostat to work.
You can also do it manually, this is what I advise you at least once a year: You open the tap on the hot water side and the pump, until there is no water at all, then on the cold water side also until the tank is empty, then you leave the taps open but above all you turn off the pump. This will protect the entire water system. You cannot reach the water heater, you must empty it by tap, starting with hot water (even if it is not in operation, this will empty it completely)."
I'm posting this in case anyone needs this information in the future
