How much solar and good source for kit? (1 Viewer)
Mar 3, 2021
10
9
Looking for one
Hi all, we’ve purchased a 1998 Fiat Ducato Suntor Swift and would like to install solar to reduce reliance on EHU. I expect we’ll mainly want to charge a couple of phones, with occasional TV, and anything else that reduces the frequency of gas refills. I get the impression that oven (microwave or conventional) would only really be possible on EHU?
Two questions:
  • Is 100W sufficient or is there some point at which you could feasibly run an oven and higher demand devices? See the image below, but looks like there’s quite a bit of space for panels.
  • We’re looking at the 100w Rigid solar panel kit with 10A PWM charge controller for £215 from this site: https://www.solartechnology.co.uk/product/100w-rigid-solar-panel-kit/. Does this look reasonable?
I have viewed several similar posts on these forums and think that 100W through this supplier seems reasonable but would appreciate confirmation (or warnings!) Thanks in advance!
Jan 19, 2014
9,385
24,754
Derbyshire
Elddis Accordo 105
since 2014
Your usage is about the same as ours. I installed a Photonic Universe 150w panel and Votronic duo 250 mppt controller which also maintains the starter battery. Mppt are more efficient when overcast apparently 👌
It supplies plenty of power and we never need EHU, oh actually just for the hair dryer.
Sep 29, 2009
969
665
East Anglia
Roller Team
fist job climb on roof and measure what size and shape of panels could be fitted Then length of cable to get to battery. Solar won’t save any gas. But allows more time without hookup.
we installed a kit from sunshine solar, despite being 7m mh could only fit a slim 100w panel on the roof because of 4 roof vents. That does us fine.
11,932
9,075
Hi, Bimble solar 😉 they do panels and kit's if needed.
If memory serves me right they have a budget kit with a 200 w, ish panel using mppt Victron controller (about £85 ) for just over £200 👍👍 Always been good for me. Make sure on size of panel to fit on your roof 😉 I would also fit a second leasure Battery
Jan 19, 2014
9,385
24,754
Derbyshire
Elddis Accordo 105
since 2014
I wouldn't fit a second battery, in your case a waste of money. In the morning our battery is never lower than 70% (got a BM1 monitor😎) and that's when Ann's fallen asleep with the TV on til 4am 😆
Nov 19, 2019
793
2,605
Challenger 287GA
Since 2020
I'm a bit confused about the oven thing? Unless it's an electric oven, no amount of solar is going to reduce the amount of gas you use! If it helps, think of solar (on a sunny day at least where your panel is in the sun) as a trickle charger being connected to your leisure battery. It won't help you with any huge, burst-type demands (think hairdryer or similar), but after that huge whack has been taken out, it will slowly replenish it while the panel is in the sun.
So - to answer the question about running higher demand devices - it would depend on your leisure battery. IF it is tiny, then big demand devices are still going to deplete the battery in minutes. You could, i suppose, cover your entire roof in solar panels but it really isn't feasible or cost-effective to so it due to other considerations.
11,932
9,075
Well the extra lb is the first thing I would fit before solar 😁 A extra battery is 60 / 80 quid and very easy fit which may well do anyone's power needs😉 For years I did without Solar. It was only when Solar became so cheap that I bothered fitting it 😁
Jan 8, 2013
8,490
11,527
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
sorenson
Mar 3, 2021
10
9
Looking for one
Thanks all, will check out the other suppliers - looks like there are a few good value options. I'll be up on the roof with a tape measure as soon as it arrives on Friday!
The gas was more in relation to devices like the fridge that can run on either gas or electricity - as I understand it, but I'm very much new to this!
Jan 19, 2014
9,385
24,754
Derbyshire
Elddis Accordo 105
since 2014
Forget running the fridge on solar if it's a 3 way. Electric wise they only work off the van's alternator or mains, they use too much power for solar, it's not impossible but don't even go there 😁
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
You need a special fridge to run off 12V/solar (a "compressor" fridge).
A standard 3 way gas fridge can't run off the battery, even though it has a 12V element. That is intended only be run off the alternator when driving along. It would flatten your battery in just a few hours if you contrived to connect it up.
I2C
Feb 2, 2015
257
610
Northamptonshire
Low Profile
Since 2000
I'm just in the process of going for solar. Taking in all the advice here I'm going with 2x80w panels, best fit for the roof space we have. Also going with the Votronic MPP 250 that others here use, can trickle charge the cab battery, saves me the cost of a battery master which was on my list as well. I'm using different suppliers for my shopping list, gives me what I want for the same price as a kit but to my spec.
Oct 9, 2019
4,953
17,293
Todmorden
Van conversion
FUNSTER in a PVC
Agreed I can confirm that my Thetford 12v fridge works fine on battery and solar.
Nov 19, 2019
793
2,605
Challenger 287GA
Since 2020
If you have a 3 way fridge, you can, as the name suggests, run it from 3 power sources. Number one is from mains electricity, number two is from gas and number three is from "battery". The "battery" part is misleading as, as stated above, it isn't really intended to run from your battery at all, more from the alternator of the vehicle when the engine is running.
So, in general, you usage is like this:
Driving around - running from "battery"
Parked up with mains electricity - running from mains
Parked up with no mains - running from gas
Newer fridges tend to be automatic and will choose the most suitable source all by themselves. Older vans are unlikely to have this and so normally you have to be aware of what you're running from. Some vans will drain your battery if left on that setting, some (mine included) will just turn off in that situation. Hope that helps, but if not just pop down any questions and we'll get some answers to you!
sorenson
Mar 3, 2021
10
9
Looking for one
Thanks all. Yes, it is a 3 way fridge but, as you guessed, I hadn't realised the battery option was only whilst driving. Noted!
Sep 10, 2012
2,132
3,708
worcester
Sunliving van
Previous van with 3 way fridge and 100w solar and gel battery was fine.
New van 300w solar compressor fridge and lithium battery.
Marmite
161
672
SW Hertfordshire
Dethleffs T 6757
Just a reminder .. when you measure up, don't forget to include the mountings in the available panel dimensions
Jan 27, 2018
2,672
2,125
Northampton
Rapido & Bongone
No
Battery operation is not just whilst driving.
All things are available to all people , just a mater of choice and cost.
Last van had a compressor fridge that uzed to be moved into the awning and run off the 100w panel on the trailer (also had one on roof).
Now have a huge 3 way aes fridge (semi)designed to use excess solar power. I am in process of sorting this out.
Only have 550w of panels on a 6m van.
Almost All things are possible some are more prevelant than others due to age of equipment and cost being the main drivers.
Running silly mains coffee pod machines is possible, some here do i never will, not because of outlandish outlay but because i drink Tea. Back to choices.
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
Anything is possible if you throw enough money at it (& a little knowledge), but let's look at the realistic requirements & expectations of the OP.
A reasonable expectation would be to run lights, water pump, TV, phone chargers & maybe a laptop charger. For now, forget anything that requires heat - that includes the 3-way fridge. There are two considerations - producing the electricity & then storing it.
Leaving aside EHU (which is the objective), there are two sources of electricity - the alternator & the solar panel(s). How much you get from the alternator will depend on how you use the van. If you move every couple of days & drive quite a long way to your next stop, the contribution from the alternator will be (or can be made to be) quite significant. If you stay in one place for a week at a time, you will need to get most of the power from the solar panels.
If alternator charging could potentially contribute a significant part of your power needs & you are up for a bit of DIY, then given the make & age of the van, the cheapest method of improving the charging capability will probably be to double up on the wiring to the leisure battery. There is a good chance that the length & size of the wiring will cause enough voltage drop to have a significant effect on the charging current. It would be good to know what control panel is fitted, because it would appear that some systems actually rely on undersized wiring to limit current flow through other components in the system.
if you can plug the van into EHU at home, then fitting a second battery as Terry suggests will immediately double the amount of power you start off with. It also doubles the storage of whatever the alternator contributes, assuming you drive far enough.
In a UK summer, a 100W panel should just about cope with light, water pump, phone charging & some occasional TV. A second battery will help for when you get a run of miserable weather. That's when you get half the expected power coming in but use twice as much, because you sit in the van watching TV while it pours with rain outside. If you want to use the van throughout the year, then I'd go for 200W, a decent MPPT controller & a second battery - and still expect to need EHU from time to time.
