How much do I weigh?
Shellie
Fiat
Hi all
I would to know how much my van weighs. I have 2 main questions
1. What's the best way of weighing a van? Do I go full of petrol and water? Or as little as possible
2 Anyone know a good weigh bridge near sittingbourne in Kent?
Best way of weighing it is to load it up fully for a trip them weigh both axles, a full tank of fuel, full gas cylinders and as much water as you normally travel with (we always travel with a full tank) & your passengers. Don't forget food & beer can easily weigh 10 to 20kg.
If you google weighbridge near sittingbourne you will be able to find one. Our local one (West Sussex) is a metal recycler. Cost £5. Drive on for whole weight and then forward leaving rear wheels on scales for rear axle weight. Subtract rear from whole to give front. Ticket gives the weights and says driver and passenger included. We normally weigh ours with full water and fuel and all the stuff for a week away.
Weighed ours this week as we are having E&P levellers fitted soon and we have just removed a table from the dinette.
Upvote 1
West Sussex is very posh. We have scrap yards they have metal recyclers. Haha
But just be mindful that if like us your fresh water tank holds 170 liters that’s 170 kilos - quite a lot of payload that you could use for something else. We carry about 30 liters when traveling as we are usually on a camp site not free camping.
Reactions: Les
That interesting the weight business as the plate on mine shows both the max weight 3500kg, rear axle 2000kg and the front axle 1850kg so the sums do not add up! IMO the max weight overrides the two axle weights added together.
They're not supposed to add up. You have your total max weight, and then each axle has it's own limit. You cannot overload either axle if you want to be legal.
Correct, now if you go back and read how the axle weights were established you will see what Ian Bosman means.
Weigh it loaded with whatever will be aboard when travelling.
In Sussex one can use the weighbridge at council public amenity sites. (One understands that elsewhere they are known as 'Tips' or 'Dumps').
Local farms and haulage companies here have weighbridges :) We use one at a haulage company and weigh once a year on our way out on a trip so fully loaded with full fuel and gas and a half tank of fresh water plus bikes and kayaks and all the gear. We know we can dump most of the fresh water if we need to. So far all has been well with both axles within limits and 90kg "spare" overall.
Yes, read how the axle weights were established in post #4.
Well, I was replying to post #8. He seemed surprised that the axle maximum weights didn't add up to the total maximum. Not sure how post #4 is relevant other than to confirm what I said. We're probably all agreeing. :giggle:
Brilliant, post #8 is quoting post #4. I'll leave that with you.
Is it still possible to find a scrapyard with a precious metals licence? I used one in London years ago & had no trouble finding one but these days there don't appear to be many.
I have & you have still lost me. :unsure:
Ian Bosman
Axle weights vs gross weight... Easy.
The gross is 3500kg
Front axle 1850kg
Rear axle 2000kg
The difference between combined axle weights and gross weight is to allow for uneven loads.
Load the rear axle to its limit of 2000kg then the front can't weigh more than 1500kg
2000kg plus 1500kg = 3500kg
Works the same the other way round...
Front axle 1850kg then the rear axle can only be 1650kg.
1850kg plus 1650kg = 3500kg
Works the same with any permutation of weights.
3500kg is the absolute maximum.
Post #4 States, Our local one (West Sussex) is a metal recycler. Cost £5. Drive on for whole weight and then forward leaving rear wheels on scales for rear axle weight. Subtract rear from whole to give front.
Is that the correct way to establish axle weights?
I don’t know that one I will have to ask. The only one I know West Sussex way is Sussex metals , owned by a bloke called Fred. I think it’s harder to get the licenses now for that sort of work.
Evidently it depends on the type of scales.
Some old ones need you to be central of the platform and with most motorhome wheelbase that isn't possible to get the front off with the rear central. .
It probably works fine on modern digital bridges.
Subtracting the rear axle weight from the total weight will give you the front axle weight?
Read my post again.
If you need the rear axle central on the plate to get a reading how do you do that on a 40ft scale and keep the rear in the center if you only have a 16ft wheelbase.
Read my post again.
This is my last go at this, go back and read post #4, is that the correct way to establish axle weights?
Its the way they do it at Geo Richardsons at Goddards Green and also at one near Hastings which we used previously. I prefer the ones where you drive over a single plate which weighs each axle in turn and adds them together to give all up weight but sadly the DVSA one I used to use at Lancing is no longer in use and the similar one at Handcross is not open to the public hence I ended up at the scrappy.
That's the scrappie where I go as it's 2 miles from me. I went to school and youth club with George's (very wealthy and now retired) sons.
Last time I drove in with my 25 yr old m/h the younger son, Bernie waved me away, saying: "We don't take vehicles".
How we laughed. :rolleyes:
That's where I go as it's 2 miles from me. I went to school and youth club with George's (very wealthy and now retired) sons.
The Civid Site in Perry Barr, Birmingham has a weigh bridge, used it a couple of years back.
