Ive progressed to having a poynting antenna to put on the roof of my van. On the attached photo you might spot the existing puck at the rear nearside of the rood with the hole for the cable just behind the skylight. As you can also see I've got aluminium roof rails and an awning permanently on the roof.
Putting the new antenna in roughly the same area lets me reuse the drilled hole in the van roof for the cabling and drops down to a location for the router where I have already got power available.
So my question is about best location to maximise effectiveness of the antenna:
can I mount the antenna flush to the roof between the skylight and awning (part of the antenna will be above the height of the awning but not all).
or
do I need to raise the antenna so the base is above the awning casing to get the best signal?
Thank You
or
Thank You
