- Jan 31, 2016
- 2,200
- 4,071
- Hymer B534 DL (2017)
- Well travelled
This pretty much sums it up other than it doesnt hurt to go to a higher load rating tyre to give you a bigger safety margin , with the ability to run at a lower pressure for a given load . You cannot really get too high a load rating for a given size , as size needs to increase to go above so called XL or reinforced levels in the nominal size fitted to your vehicle .You need to know your max permtted axle weights.
Perhaps your rear is 2400kg, you would need a tyre capable of supporting 2400/2 so 1200kg.
116 rating is 1250kg per tyre, so 2500kg per axle.
What is tyre load rating? | Tyre load index | Blackcircles.com
Buy tyres online and get them fitted locally with Blackcircles. Lifetime Guarantee now on all car, van & SUV tyres. Peace of mind, at no extra cost.www.blackcircles.com
This shows the load ratings , you might decide to go higher if you intend to uprate an axle later.
