How big is my solar panel?
Twos company
Boroughbridge
VW transporter
Hi my vans solar panel has no info how can you tell it’s potential output
If you can advise some approx dimensions,that may help. Also if it is a stuck down panel or mounted in a frame.sometines you can check underneath with a phone camera and take a pic of the info label which should be close to where the wires feed into the panel. (y)
Very roughly, about 180W per square meter.
If it helps my 130watt frame mounted panel is 664mm wide x 1179mm long x 35mm deep.
