How accurate is onboard computer? (1 Viewer)
Mar 24, 2010
1,072
765
stoke on trent
relay lwb pvc
6 years
Often wondered how accurate is the onboard computer as average ongoing "mpg" is concerned(Relay 2,2) ?
43,295
49,268
Check it and see.
Fill tank
Zero MPG
Drive til nearly empty
Refill to top
Note litres needed to fill and current mileage. (Divide litres by 4.54 to get gallons)
Calculate MPG
Check against computer.
Personally I find the MPG computers a waste of time....when you need fuel, you need fuel.
1,444
2,843
Colchester
Le voyageur 8.5
On 3rd van so not a total newbie....
Overall I think the fiat one is reasonably accurate, the issue I have is filling consistently, as it suddenly fills and will spurt back, as a result, I only now fill to the first cut out, which depending on pump flow could be a couple of litres more or less than I have used.
Reactions: f6c
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
I do not know if it is accurate but mine says between 14.1 to 14.4 km per litre from start on a new trip per day, usually at a steady 55-60mph.
Oct 30, 2016
1,444
2,843
Colchester
Le voyageur 8.5
That's about 40mpg! Is that downhill all the way?!
Bart
3,188
1,397
Northern Ireland
Boxer L4H2 van build
Since 2016
Mine lies to me........ Tells me i'm getting 30mpg where as I am actually getting 24mpg
Lenny HB
53,304
149,474
On the coast in West Sussex
Hymer B678 DL
All three Ducato's we have had have been accurate between 0.2-0.5 mpg compared to tank brimming method over several tank fulls. Always tend to read slightly under.
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
Mine reads slightly under, it will show 28 - 29 m.p.g when I am actually getting 30 - 31 m.p.g. on tankful to tankful. I record all my fuel purchases.
Jul 3, 2008
1,098
943
Lincolnshire
Autotrail Apache 700
since 1998
I never worry about fuel consumption, I look at it as,if I have to worry about a mile or two more or less from Fiats figures, then I cannot afford to run the van in the first place.:cycle:
May 7, 2016
7,230
11,699
West Sussex
Carthago Compactline
Since 2003
Possibly litres per 100km, which is how my Merc based Hymer measures it, and that is nearer to 20 mpg than 40.
Oct 30, 2010
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
I use a fuel app on my phone to log fills and the onboard Fiat computer seems to mirror my results. Cant tell exactly as I zero the trip so frequently.
Richard.
Oct 27, 2017
1,407
3,136
Perth
Hymer A Class
Since 2014
Last October our 130hp Ducato-based Hymer showed 26 mpg for 2000 miles around Italy and Croatia. On the way home it suddenly went to 5.6 mpg. This was on both "A" and "B" journey logs. I have no idea why. I've subsequently replaced the starter battery, so the computer has reset. Any ideas?
Oct 30, 2016
1,444
2,843
Colchester
Le voyageur 8.5
Dpf regeration?
Oct 27, 2017
1,407
3,136
Perth
Hymer A Class
Since 2014
Really? I didn’t even know this can “happen” automagically!
Aug 14, 2013
581
618
Département 87
Profile
Since about year 2000
Your calculations are only as accurate as your speedo / odometer. In theory, therefore, you may be getting a figure which is up to 10% to your apparent advantage.
J
