I need to wire in a double light switch in my garage to 2 separate lights from a junction box I shall be connecting from between one of the lighting circuits in the loft space.Can anyone show a diagram?
What alterations?.....a ‘Part P’ certified one......as solicitors always want to see certification for alterations to house wiring when you come to sell!!!
But not the certificateWhen I swapped our consumer unit for a modern one, I bought it off ebay second hand but nearly new that way it comes with all the tested stickers
Ideally steel wire armoured (SWA) and buried, with warning tape over it, to 18".If running a cable to garage it might have to be armoured.
They're up to 18th edition nowYou need a Part P 17th edition qualified electrician to carry out that kind of work. And if you haven’t got an up to date mcb distributon board it could get costly.
18th Edition nowYou need a Part P 17th edition qualified electrician to carry out that kind of work. And if you haven’t got an up to date mcb distributon board it could get costly.
Perhaps I didn't explain very well but that's correct..The loft is above the garage where I can break into the lighting circuit and feed a twin light switch below in garage to supply 2 separate lights.I think your picking up a live feed from the attic and you need that to feed two lights that run via two way switching if I read the first post correctly.
If you need to ask the question, then you aren't competent to carry out the work.
Assuming easy access, I'd suggest a qualified spark to charge around £200 for that work.
Not necessarily, here's what does require certification
"Notifiable jobs include:
Most repairs, replacements and maintenance jobs, and alterations or additions to existing circuits outside special locations, are not notifiable."
- The installation of a new consumer unit or fuse box
- The installation of a complete new circuit – for example a ring or lighting circuit, or a new circuit for a cooker, shower or immersion heater
- Alterations to existing circuits – such as adding an extra power point or lighting point – but only in ‘special locations’. In England, special locations are the spaces around baths and showers. In Wales, special locations include also kitchens and outdoors.
Building Regulations: General information - Electrics - Planning Portal
Details of the planning permission and building regulation regimes for Electrics in Englandwww.planningportal.co.uk
It is worth pointing out that the list you have shown contains only the items that need prior notification to Building Control before starting work.
All electrical installation work in your home or garden (I am only referring to England, as Wales and Scotland may be different) must comply with the Building Regulations.
Absolutely
But the list also includes items that need to be certified by an approved person.
Other works can be undertaken by anyone, I have just completed a 2 storey extension including extensions to the lighting and ring circuits, the project was subject to BC inspections, but once the BCO was informed there were no items on the above list, he wasn't interested in the electrical works (I have a completion certificate from BCO should I need it for house sale etc)
