Hot Water and Hot Air Heating not working - Kingham Autosleeper (1 Viewer)
Apr 3, 2023
3
Kingham Autosleeper
Hello
Just getting the Kingham ready for the our first trip of the year - everything seems fine but I cant get the Hot Water of the Heating working .....
There is water in the hot water tank and water coming through but unfortunately its not hot!
Is it something I have turned off when I winterised it .... and need to switch something back on?
Any ideas would be gratefully received - thanks in advance
Gideon
Mar 23, 2012
9,089
29,662
sleights
c class
Hello
Gideon
Are you heating it by gas or electric?
Dec 24, 2014
8,463
41,679
Hurstpierpoint. Mid Sussex.
Compass Navigator
Ever since lighting was by Calor gas.
Welcome!
Possibly, but I can't see from here. ;)
Are you seeing any 'Fault' lights showing on the control panel?
As a start to finding the problem......is the gas hob working?
Each gas powered item will have its own shut-off valve, sometimes the water heater valve is separate from the main group of gas valves on the gas supply manifold. It's likely to be near the heater, perhaps in a locker or under a seat/bench. If you closed it when winterising, have you opened it now?
Or it may be electrical, especially if it hasn't been used over winter, e.g. is the leisure battery fully charged and all 12v systems switched 'On'?
Do you have an electrical test meter?
G
Apr 3, 2023
3
Kingham Autosleeper
Welcome!
sorted now thanks, i had to press and hold a couple of buttons on the control pad - doh!
Feb 25, 2018
5,431
11,946
Essex
Adria 670 SLT
Most if us have been there, so don't worry. Just make sure you have a copy of the instructions ready for when you forget again next year lol ! Yes, some of us have done that aswell!
Jun 29, 2015
3,304
52,582
Southampton
caravan (for now)
on and off since 1984
I think many of us have been in a field, in the middle of nowhere, trying to remember what worked last time šŸ˜‰
