Hosepipe (2 Viewers)
RayandLinda
68
59
South Wales
Auto trail Tracker
I'm a newbie
Me again! The pitch we are going onto is fully serviced and last time we had a pitch like that, we needed a hose to fill up the water tank, but to date we haven't got one, so looking now. Is there any particular type, size i need to get and what length would you recommend please? Linda
DBK
17,969
47,804
Plympton, Devon
PVC, Murvi Morocco
If you really want to make full use of the serviced pitch a corrugated waste pipe might be useful. It needs to be big enough to fit over your drain tap and long enough to reach the drain point. But I wouldn't bother even though we carry a short length. :) What you will need instead is a bucket of some sort which will fit under the drain tap. This means it can't be too high. You could use a small washing up bowl but a collapsible bucket is what we use and we carry two because that reduces the number of journeys to the disposal point. :)
kevenh
3,319
11,801
Thatcham
Compass C-Class
I'm a Progressing Newbie
We've a long flat pack food grade hose.
But mainly we use a floppy 20Lt bucket with an external water pump. Our MH has a handy power socket for the pump.
We've also got a funnel for an alt. way to add water :eek:
11,793
13,948
Eastbourne East Sussex
Hymer low profile
Since 1972
Depending on where you travel you may need the 1" Screw on adaptor, which doesnt come with the standard adaptor. Also some bournes have a hoselock connector which doesnt need an adaptor at all.
Langtoftlad
8,832
148,802
Langtoft, South Lincs
WildAx Aurora FB [PVC]
Since 2015
Watering can...
It's length is never too short, never too long.
I have one of these "patio" hose reels
4539663_R_Z001C
Nice and compact - but the only time I seem to use it, is to do the initial fill up at home.
2,999
6,924
Hymer Exsis
20 years
Maybe lead isn’t used but copper is. I don’t think copper would be classed as food grade.
Really? Food grade means nothing will leach into the product. Copper doesn’t leach into water.
You might be right but I am fairly sure Copper is classed as food grade for water.
kevenh
3,319
11,801
Thatcham
Compass C-Class
I don’t understand the food grade hose thing. The pipe work right up to the tap isn’t food grade so what’s the point of having the last few metres food grade?
As someone with several hoses, the blue food grade hose we have is just a standout hose that doesn't get used for watering flowers, etc.
They needed cost much more than a regular hose.
ymmv
EDIT: small typo fix :eek:
glenn2926
3,326
13,619
Gods country
Chausson
newbie hired 3
Also, how do you know, that’s definitely know that the whole of the route your water is taking from reservoir to tap is not through any lead pipes?
60
34
clevedon uk
Autotrail Cheyenne
Since Feb 2018
On the question of connectors, despite having a connector similar to this:
I have never been anywhere where I needed anything other than these standard connectors:
As for hoses, I do have a food grade hose but I never understand why! After some years it must surely develop bacteria and I would never dream of drinking the water from my fresh water tank anyway. The best thing about my hose is not that it is food grade but that it is on a reel and tidies up nicely and does not need a lot of room to store.
If you go abroad you’ll need as many different connectors as you can get 🤣
joka250
907
1,554
Fylde Coast.
Since 1985
If you don't drain hose after use you will get bacterial growth in any hose
Because it is food grade won't prevent this.
Ordinarily I would agree but the tests we did with HSE tended to show differently,they aren't definitive but for 6 months we ran standard against food grade, always same tap and as near as possible same usage. Each hose was flushed through every 2nd day with a disinfectant solution and fresh water. After 6 months the bacteria was present in small quantities in standard but not food. The trial was not taken any further forward so lots of questions remained but it convinced me.
I should add that the issue was caused by aerosol affect, all droplets caused by spillage from the hose had the potential to be inhaled.
TheBig1
17,509
42,755
strange but true, copper is classed as suitable for potable water and not only does it not leach chemicals, copper is also anti-bacterial. Not only was it commonly used in kitchens before stainless steel but also as the surface on operating table tops
3,548
9,881
PVC
1995-2004 & 2017》
So you agree.....BUT...
Minxy
32,488
66,008
E Yorks
Carthago Compactline
Minxy
32,488
66,008
E Yorks
We don't bother with food grade ones, just a good quality anti-kink hose cut into a long and short section with ends on so they can be connected:
This is my website and at the bottom of this page you can see the hoses I use along with how I 'hook' then on to fill the tank single-handedly and also make them easier to store.
As for fittings and other bits and bobs ... I've got loads! Below are images of what I used to have, since then I've added to my collection. :giggle:
