Hook up cable
Jan 31, 2016
1,466
1,727
Alness, Cromarty Firth
Hymer B544 (2012)
newbie
I had a problem at garage with my hook up. It plugs into external socket (3 pin plug 13amp )on side of garage with closable lid making in water proof, IP66.
But the fly lead adaptor to fit my 25m blue 16amp lead (industrial connector to 13amp plug ) isn't water tight to IP66, only being IP44 and lo and behold when I parted the two they were full of water. Hope this makes sense.
I'm wondering if the hook up lead when fitted with a blue plug (to IP66) will fit on my van as the cover looks quite chunky ?
https://www.toolstation.com/shop/Electrical/d190/Industrial+Connectors/sd2430
Aug 26, 2008
3,055
12,526
B&NES
Van Conversion
since 2007
That's why I have my fly lead adapter plugged into a 230v socket inside my garage and feed the EHU lead through the door frame.
BusyBuilder
Jan 31, 2016
1,466
1,727
Hymer B544 (2012)
newbie
Sorry I knew it sounded confusing, it's the fly lead to long lead that's filling up with water not the 13amp plug/socket on the wall. So the two blue pug/socket parts.
Aug 26, 2008
3,055
12,526
B&NES
Van Conversion
since 2007
Ah, now I see. In that case, Duck tape round the joint of the blue parts would be my answer.
But I am not a Sparks, only a bodger.
golly
1,811
33,753
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
I had a spare cable so fitted a normal three pin plug in place of the hookup plug so plugs into outside socket.with no need for fly lead
