Hook up and starting engine? (1 Viewer)
rf9ridrer
78
38
2007 ACE FIRENZE
Maybe a daft question, but if you are connected to EHU, is it safe to start and run the engine?
Thinking the leisure battery is getting a trickle charge from the electric, but wondering if the alternator would cause a problem?
Lenny HB
50,179
138,271
On the coast in West Sussex
Hymer B678 DL
I posted about this a few years ago a lot said on here it was fine to do but on our Hymer S820 2004 it knackered the charger and Electroblock.
Unusual Elektroblock are normally OK with it.
Only problem I had was breaking the inlet socket when I drove away with it plugged in. :eek:
Puddleduck
12,218
42,774
Scottish Borders
SunLiving Lido M45SP
On and off for many years.
Unfortunately we have done that as well :( In our case tha damage was to the site's bollard. We did admit to the damage and paid for the repair.
It would really help if there was a buzzer or similar that alerted the driver when the ignition is turned on with EHU still attached.
May 5, 2022
1,725
11,312
Kidsgrove, North Staffordshire.
Hymer B778 PL
Since 1992
Our Hymer has a buzzer if the EHU is plugged in. Same with the habitation and cab steps if they are out and the satellite dish folds 8tself up. Does not empty the toilet though.
rf9ridrer
rf9ridrer
78
38
2007 ACE FIRENZE
Best not too, some systems can cope with it some can't.
Why would you want to?
On EHU the vehicle battery is not being charged, so wanted to run the engine for a bit to keep the battery up.
rf9ridrer
rf9ridrer
78
38
2007 ACE FIRENZE
Thanks all, guess i will disconnect before starting up.
Mar 14, 2020
538
442
Isle of Man
Autotrail Cheyenne
Since 2015, still learning
rf9ridrer has it ever been able to charge the vehicle battery on ehu? A pic pf your control panel may help. The only AF panel I have seen had the option to draw from, or charge, the cab battery at the push of a button. You can tell if it’s working by looking at the voltage readings on the panel. If it goes up singificant,y the it is giving a charge.
cush.
Lenny HB
50,179
138,271
Hymer B678 DL
You really don't want to do that unless you have deep pockets.
Modern diesels should be driven off immediately after starting. Should never be left on tickover from cold.
Feb 3, 2020
196
241
hartlepool
Hi Top
Hit the road in 2014
I have been close to doing this a couple of times fortunately I have a long lead and managed to spot it at last moment. I don't suppose we are the first and won't be the last. Happy camping
Mar 6, 2008
113
125
Spixworth
Van Conversion Moto-
Since 2006
Our Moto-Trek PVC has a Sergent power system which emits a loud warbling noise when the ignition is switched on if the EHU is connected and powered up. I haven't tested if it works with no power on the EHU. I have also drove away with the EHU still connected!! Not any more though.
Oct 27, 2017
1,291
2,587
Perth
Hymer A Class
Since 2014
The cable doesn’t half stretch when you drive away, before one end or the other rips something out. :)
Bobbydaisy
517
747
Elddis CV20
Our Sargent unit on our Autotrail had a button on it to swap from leisure battery to starter battery charging . Wouldn’t sit with the engine running for any great length of time , invest in a plug in battery maintainer/charger to top up the starter battery when on hookup for extended periods, much cheaper than a new DPF 😲you can permanently wire in the plug and socket lead to the starter battery so you can easily connect the maintainer/charger , we use the Optimate , link below. Also our solar panel controller charges the starter and leisure batteries, another way of maintaining the starter battery for you perhaps .
Feb 22, 2016
3,354
9,779
York
Bailey 620 Approach
Since 2015
Yes, keeping cable connected you can get to Dover from York in just over 7 hours and back in about 20 seconds!😀
Apr 13, 2019
1,649
38,861
Nottinghamshire
Ci Coachbuilt
Since September 2018
Thats what I now do with a stand alone Ring battery charger plugged into a 240v socket in the van and inserted into a permanent live cigarette 12v socket, when at home if cab battery gets a little low and also when on site if on ehu.
The leisure battery is of course charging on ehu via the ancient on board charger.
When rolling however, both batteries charge from the alternator, which can also power the fridge on 12v.
Simple, but effective and works.😊
Jan 3, 2013
124
172
St.Neots Cambs
Hymer Exsis I-414
2002-2006, 2013-current
Been there, done that Lennie-feel a right fool don’t you……
Aug 12, 2021
184
175
chausson
On the ambulances we had the 230v shoreline to keep everything charged up. They are fitted with an auto-eject, which in essence is a solenoid which triggers under starter motor switch on and fires the plug out of the socket, this was devised due to the umpteen accidents, yours truly responsible for 3!
Feb 3, 2022
38
56
Bessacarr E695
We have a laminated check list to avoid this, although it also includes "remove cab window blinds" which I now realise is a bit unnecessary.
Steve-N
160
237
Cheltenham, UK
Fiat Ducato Camper
2nd Campervan since 2019
I have a split charging solar system, so both the leisure and van starter batteries are being charged all the time.
Re driving off with the cable plugged in I always do a mirror check before moving, I can easily see the cable if I've overlooked it.
As a thought, it should be quite easy to rig up a small warning light on the dash which is illuminated when mains voltage is 'present' ie the ehu is connected !!
rf9ridrer
rf9ridrer
78
38
2007 ACE FIRENZE
cush.
Only had the motorhome 4 weeks, its an older model, a Swift Ace Firenze, the control panel is this one in pic.
I have looked on youtube etc, someone says the cab icon button is for emergencies only to replace leisure battery source, someone else said you can charge the vehicle battery from this button?
I can check vehicle and battery voltage readings on the panel, but vehicle battery shows no change on EHU
Oct 9, 2019
4,677
15,924
Todmorden
Van conversion
FUNSTER in a PVC
As a number have already suggested, get a Vanbitz Battery Master fitted it will do what you want without having to run your engine on idle.
