tick59
Do you leave your router switched on at night or switch it off? What is the best thing to do on or off?
Leave it on it stabilises your broadband connection, you will find that's what your provider recommendsDo you leave your router switched on at night or switch it off? What is the best thing to do on or off?
In my experience all externally facing IP addresses are under constant attack. A router coming online will get tested by automated probes within 20 seconds or so. A permanent IP address really makes no difference. There are thousands of 'bots' testing every IP address permutation all the time. The important thing is not to leave ports open especially port 80.If you are worried about security turning it on and off will mean it gets a new IP address. If you leave it on permanently your house effectively has a permanent IP address and this could be exploited. Whether anyone would bother to attack your home WiFi is a different matter.
By IP address I mean the address the www sees, not the 192.168.x.y. address used internally.
I have fixed ip a hangover from when I had a business account and needed it to set up vpn's.If you are worried about security turning it on and off will mean it gets a new IP address. If you leave it on permanently your house effectively has a permanent IP address and this could be exploited. Whether anyone would bother to attack your home WiFi is a different matter.
