Changing the single 13a socket. for a double.
Before I start drilling, has anybody done this. Don't want to break it etc.
Cut it from the back if you can and put some tape over the cut line to prevent spalling the edgesChanging the single 13a socket. for a double.
That means he will be drilling in from the outside, going to be a bit drafty with that hole in the wallCut it from the back if you can and put some tape over the cut line to prevent spalling the edges
No I think he could take it off the wall firstand as Lenny HB said there’s an awful lot of cables behind itThat means he will be drilling in from the outside, going to be a bit drafty with that hole in the wall
Clipsal stopped trading years ago and that would look awful in a Hymer. Mods should always look like they were an OEM fit.Clipsal used to do a twin switched socket that fitted on a single socket box if thats any easier
I've got the double socket. Ready to cut.Clipsal used to do a twin switched socket that fitted on a single socket box if thats any easier
That sounds like the ideal but I'm fitting this in the real world.You need a diamond hole cutter, used for tiles. Drill through a piece on sacrificial ply, and use that as a template to guide the cutter.
A hole saw will work if you very careful. You need to cut in reverse, as it will bite to much. Before you start, you need a small pilot hole. I have done it in fragile polycarbonate.
I've got 2 in the garage, 2 behind the TV where I don't need any, one beside the table and still finding them but I like my toaster and kettle on at the same time, preferably in the kitchen.As long as you run the drill on slow it will cut fine more of a concern loads of cables run down behind there.
But why? Is another question there are 5 sockets in our van we occasionally use one of them, sorry 4, I removed one.
Do you know how?No I think he could take it off the wall
Just fitted these cbe sockets. The 13a are the same.Clipsal stopped trading years ago and that would look awful in a Hymer. Mods should always look like they were an OEM fit.
Not a clue I’m afraid as I have not tried, I’ll have a look and see if I can suggest anything thoughDo you know how?
Schneider bought up Clipsal when it liquidated and still sell their accessories. If the new socket was being installed in an area where it was not seen then there wouldn't be a problem what make was usedClipsal stopped trading years ago and that would look awful in a Hymer. Mods should always look like they were an OEM fit.
I can relate to that. But the thought of running a course toothed hole saw in a hand held drill on a vertical sheet of wobbly perspex.........I’m different to most it appears. I would run the drill as fast as possible, and then progress as slowly as possible. I find that running the drill slowly causes the teeth to bite to much, shaking you, the drill bit, and the hole all over the place. That’s certainly my findings drilling plastic sinks, basins, baths and more as it’s part of my job.
Let us know how you get on.
See post #16Schneider bought up Clipsal when it liquidated and still sell their accessories. If the new socket was being installed in an area where it was not seen then there wouldn't be a problem what make was used
Here’s your answer gently prise off the top silver quadrant cover fillet with a wide bladed panel tool then you will see small screws that holds the backing strip take them out and the panel will pull towards you from top as side covers are not fixed and lift panel out of bottom channelDo you know how?
You know, it's people like you who make this the greatest "camping" site ever. Thanks, will give it a go.Here’s your answer gently prise off the top silver quadrant cover fillet with a wide bladed panel tool then you will see small screws that holds the backing strip take them out and the panel will pull towards you from top as side covers are not fixed and lift panel out of bottom channel
That’s what it’s all about if my experience as a joiner and motorhome owner can help someone in need that’s great, take it slowly and you should be ok.You know, it's people like you who make this the greatest "camping" site ever. Thanks, will give it a go.
