Rincewind
- Mar 26, 2018
- 5
- 0
Hiya,
I'm new to this, but I needed to buy a motorhome at short notice, so I could start a new job upcountry.
So, I now own an old (1994) VW T4 'Swift Royale'.
I'm pleased with it so far.
One of the things I did to improve things, was to buy a telly.
To get a signal, I bought off ebay a secondhand 'model number 6701' which is a directional antenna, with a separate amplifier.
I'm pleased to say this works well.
The thing is, at present I am parking at night and travelling to work the following morning. As it stands, that means fastening/unfastening the aerial every day, as I route the coax on the outside of the van, which is a bit of a chore.
What I intend doing, is drilling a hole in the roof of my moho, to put the pole through, then affixing a bracket to the inside of my wardrobe.
Easy enough so far.
As the antenna is directional, I want to be able to rotate the pole from inside the van, to align the antenna on the outside, to suit my new parking position each evening.
Again, not much of a problem.
The problem: How do I make it weatherproof, but still able to rotate?
(I'm thinking of some kind of silicon grease filled thingummy?)
Any Ideas would be much appreciated (I'm on a bit of a tight budget).
Thanks.
Easy enough so far.
Thanks.
