- Jul 18, 2009
- 11,187
- 17,827
- HYMER B644
I had one. Yellow.Isetta with the front opening door. Only car I’ve been trapped in. Driver was parking on grass and didn’t see a 12 wide ditch that had been mowed flush. Front wheels dropped in jamming door against ground. Fortunately others with us were able to lift it out. Memories
Whilst you could drive it on a motorbike licence, you had to lock off the reverse gear, so easy to get stuck if you parked against a wall. Most owners had it locked off with a simple screw across the gearstick selector which could be removed by handI had one. Yellow.
If someone parked too close I got out of the sunroof.
Wish I had one now. £20k to £30k in reasonable to good order
I don't remember that!you had to lock off the reverse gear, so easy to get stuck if you parked against a wall. Most owners had it locked off with a simple screw across the gearstick selector which could be removed by hand
They didn't all have a reverse gearI don't remember that!
I'm sure mine did. Without a reverse how did you go backwards?They didn't all have a reverse gear
To drive any of them at 16 on a motrcycle licence reverse had to be locked off. My mate had the reliant & that was locked off.I don't remember that!
A) you got out & pushed it back B) or you didn't go backwards.I'm sure mine did. Without a reverse how did you go backwards?
I have no idea who told you that but it's total tosh!These Isettas have an interesting history. BMW made them under licence from Isetta. Isetta made household electrical goods. The door on the car was reckoned to be a fridge door from the company's parts bin.
I never went or organised any rallies there but I know other members organised smaller gatherings so maybe they did.Did you ever go to Jasmine Park caravan site between Scarborough and Pickering ? We had our caravan there and often saw the microcar people come for a weekend .
I assume that was the same 4 gears reversedMy best friend at school had one but my favorite bubble car was the Messerschmitt KR200 which was a lot more streamlined. It had 4 forward & 4 reverse gears!
But not in most US states. We regularly saw Pickup`s with 5th wheel, towing a boat?. I asked a guy on site at Corpus Christi KOA. about it, he said some States like you to have a CDL (HGV) but many just don`t bother.Hi.
Multiple trailers.....Showmans Guild...........
Tea Bag
Yes I'm pretty sure that was how they worked although I wouldn't fancy going backwards at 62mph!I assume that was the same 4 gears reversed
Yup, same number of gears forward and backwards, I can't remember the exact way it was achieved but I seem to recall it somehow turned the direction of the drive the opposite way. This was the case on a few microcars and some brave souls (total nutters) used to see how fast they dare go in reverse! If you didn't have a full car licence you couldn't use reverse so it had to be blocked off.Yes I'm pretty sure that was how they worked although I wouldn't fancy going backwards at 62mph!
Hi Minxy Girl,Yup, same number of gears forward and backwards, I can't remember the exact way it was achieved but I seem to recall it somehow turned the direction of the drive the opposite way. This was the case on a few microcars and some brave souls (total nutters) used to see how fast they dare go in reverse! If you didn't have a full car licence you couldn't use reverse so it had to be blocked off.
Bond Minicars, on the other hand, were ONLY able to go forwards as they actually used motorcycle engines and thus still a kick-starter (many did have electronic ignition too), however many a time I've seen owners trying to get them going with their leg inside the engine compartment kicking away like mad only to start them and then have the car run them over because they'd left it in gear!!! ! The lack of reverse gear wasn't usually much of an issue though as the car's steeting literally turned 90 degrees in either direction so you could go round and round in circles if you wanted to ... one of our 'display' party pieces was the 'Dancing Bonds'.
