Hi. I have been told that it is ok to use “motor gas” for use in my Motorhome . Has anyone any experience of the use of this gas , or any observation (1 Viewer)
LUBIN
3
4
WoodhallSpa Lincolnshire
C class
Since 2011
Hi. I have been told that it is ok to use “motor gas” in my motorhome. Has anyone any experience of the use of the gas in a motorhome . Any observations would be appreciated.
Thanks in advance LUBIN
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
Do you mean LPG? You can buy the proper system from Gaslow ,or gasit for example then fill up at petrol pump. Best to get an exterior filler point fitted.
Apr 26, 2018
817
1,861
England, UK
Learning all the time
You mean like this
this a gaslow system
Apr 26, 2018
817
1,861
England, UK
Needs to be something like in photo. Not Calor gas
Shrimp
May 27, 2015
3,984
33,418
Bedfordshire, UK
Hymer B584
Long time
You shouldn’t try to fill ordinary gas bottles.
Refillable bottles are a separate thing to Calor!
With yours you will have to return the Calor bottles & purchase a new one every fill.
They don’t have Calor in France you will need a French bottle!
Southdowners
3,358
25,320
West Sussex
Concorde Charisma
Since May 2015
Unless you have refillable bottles or a gas tank then I believe you need to exchange your empty bottle for full ones.
Apr 27, 2016
6,872
7,991
Manchester
A class Hymer
Since the 80s
My van ( just purchased) has a 13 kg and a 6kg Calor bottles when I bought it
The bottles you have are not refillable. You exchange them when empty, for a full one.
Different bottles, or a built-in tank, can be refilled with 'autogas', also called LPG (or GPL in France). It is intended for vehicles that use it as a fuel, either on its own or switchable between petrol and autogas. Because of this, it can be found at some filling stations, sold from pumps just like petrol or diesel.
Refillable bottles (as in Innkeeper's pic) look very similar on the outside, but inside they have a cutoff valve that automatically stops filling at the 80% level. They also have an inlet to attach a filling tube. This goes to a filling point to which you attach the hose from the pump. Once you have the system installed, there is no need to remove the cylinders for refilling. You just drive to the filling station and fill up.
There are two big advantages - you can top them up anytime, they don't have to be empty. But the best thing is, with three small screw-in adaptors you can refill from a pump anywhere in Europe. No worries about special bottles for each country.
Oct 12, 2009
10,657
23,643
A Class N+B Arto 69GL
Since 2009
That is the full answer. The others have been partial.
May 17, 2016
3,610
7,832
Aberdeenshire
B524
2nd base
Apologies for hijacking but I wondered where you get the refillable systems fitted. Do normal caravan engineers fit it or is it specialists who would have to do the job?
I've not long bought a van with one calor bottle and one gaslow. It was in getting the fridge fixed earlier and the guy said that the gaslow bottle should really have the regulator fitted to the bulkhead. Is that right?
I think I want to get rid of the calor bottle and get a 2nd gaslow for a fully refillable system so need to find somewhere to do the work. Any ideas on cost?
Feb 16, 2013
19,731
52,009
uttoxeter
ambulance conversion
50 years
You can do it yourself, easy as changing a normal bottle and if you already have one , you have everything but a joining pipe.
Minxy
32,646
66,526
E Yorks
Carthago Compactline
If you are a competent DIYer and are happy to do it, there's no reason you can't, the biggest decision is where to mount the filler point, putting it in the locker is easiest but a pain for filling and can be shunned on at fuel stations, outside is easiest but drilling a hole in your pride and joy will bring you out in a chill ... this is the most worrying part of it all, seriously it is, more so than connecting the pipework up!
The norm is to have a bulkhead regulator but there's no reason at all why you can't have a bottle top one so long as it's the right type.
You can pick them up second-hand but need to check the 're-certification date' on the bottles to make sure £ for £ they work out a good buy otherwise go for new, Gasit are cheapest but shop around for the other parts as some have them cheaper than others and you can mix and match as necessary.
Feb 11, 2017
1,044
999
Cumbria
Pilote P740FC
Might be worth thinking about how much gas you go through before incurring the cost? I’m sure it’s worthwhile if you’re mainly off EHU - but we decided to start with one Gaslow bottle and to keep a 7kg calor to switch over to when we ran out. In 7 years we’ve never run out, so I guess it was the right decision. But we do mostly have EHU.
Apr 27, 2016
6,872
7,991
Manchester
A class Hymer
Since the 80s
There are not many disadvantages to a refillable system, but one of them is when you are staying in one place for several weeks. Many do this when they spend the winter in Spain/Morocco or do a month in a winter resort. Packing up and firing up the motorhome just to go and fill up with gas can be a pain. You could buy an exchangeable bottle for the country you are in, and swap it. Use the refillable to fill the gap between exchanges.
969
2,831
Newton Stewart, UK
Autotrail Imala 615
Since 2000
Our dealer fitted ours when we bought the van after removing it from our previous van. They put the filler in the locker. Wouldn’t put outside as they said putting a hole there would invalidate the damp warranty. Worth checking before cutting the hole.
Jul 29, 2013
9,071
18,508
Salisbury
Hymer B678DL A class
since 2011
I think they were having a laugh the outside filler can be put into the skirt so has nothing to do with damp warranty and the fill hose can come out through the gas locker drop out. ?
Jul 29, 2013
9,071
18,508
Salisbury
since 2011
You can buy a Reserve Cylinder Connection Hose which connects to your fill point and then an external gas cylinder which stands outside your van.
https://www.gaslowshop.co.uk/reserve-cylinder-connection-hose/ ???
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Minxy
32,646
66,526
E Yorks
More likely they didn't want to do the job for you as they are talking b*llocks! They try all the tricks in the book to not have to do work if they can unless they are getting paid for it.
Minxy
32,646
66,526
E Yorks
Or you can fit a BBQ point and kill two birds with one stone :) .
... then you can chuck the birds on the BBQ ... would that be 'kill three birds with one stone'?
