Rung around omg nearly 6k so went to look at the system . I'm an old engineer I have owned a few machine shops and still partner in one ive made 1000s of hydraulic rams I looked at the system and from my knowledge of cost of parts I could not get passed £1800 okay rams and hydraulic pumps are cheap so self leveling gadget must be rocket science.no . I came across an engineering company that do a self leveling system and I bought it for £2600 delivered so some of you are going to say fitting is not easy . This system is blue tooth so no wires in the cab every thing goes in the garage and because they are bouble acting rams a percentage of the oil used to push the ram out is then used to retract the oil and the rams are under pressure to stay up not using a spring as spring steel rust in time this also means smaller oil tank in garage . Good thing is the ram is aways lubricated so I'm now installing this in my arto and we will see how I get on . I will make a drill gig and share with anyone that want to do the same
Down side or is it
Self leveling some do it in 2 minutes this will not because you have to hit the ram buttons and do it your self but we are not silly and I done similar before so don't see that being a problem just look a the bubble . I've spoken to the company and said thankyou for charging industrial prices these systems have been use used for a long time on heavy machinery as for maintenance as they are British made all seals are am readily available. As soon as you say motorhome the price goes up . I'm not putting down any system but having been told 6k and if I pay 2k now they can fit me in at the end of the year . And I may have to pay import duty im sure I will hit snags and yes I have planned to make a mechanical gimbal to be lazy but I don't need it in the cab . The first thing I do when I park up is open garage door fetch water so may aswell put switch in garage save work .I would like to know if any one has made something them selfs being an engineer I can't help my self .but 6k its just not there im sure if I did clear instructions anyone could get a local garage to do it . I don't understand smthe use of single acting rams and a spring to hold it up . Double acting are not much more expensive and they are on job's out in all weather I guess if you make it a science to fit them you can charge what you want but I'm old school we were told KISS . Keep it simple stupid . I've been a design engineer and own my own patents.worked subcontract so all the difficult bits no one else wants to do .and I love it .and looking forward to meeting some fellow engineers and gadget makers its a good life if I have upset and ones products I dis not mean to .thats why ive not mentioned any company's only stated me thoughts if right or wrong guess we will know when the job is done I will not use my factory or lift only tools from home or on amazon . Drill jig might cheat and get boys to make go one so it lasts
Down side or is it
