Helppp I cannot find the water pump on/in my Peugeot boxer pilote motor home thank you
jilldowson
peugeot boxer pilote
As above can’t find water pump in my Peugeot boxer pilote motor home thank you
If you mean the habitation pump then it could be in the water tank as a submersible.
Thats the hab area water pump tell us what your problem is and help will be here shortly
Pump not working, so no water to taps
Right the pump is probably a submersible 1 in the water tank but let's start with the simple stuff and im not trying you to duck eggs here but is there water in the tank if yes can hear and whirring noise when you turn the tap on if no check fuses first if fuses are all OK locate the water tank and its probably got a cover on held in place by a few screws with a wire going into it make sure the wires havnt broken at the connector block just before they go in to the tank if all is good at this point(say sod it and go down the pub) the pump has probably kneeled over and needs replacing
It may be a daft suggestion but if the m/h is new to you...............
Are you sure the pump's not running? Have you previously heard the pump running? After refilling an empty tank it can take some time before the air in the pump and pipes clears and water comes through.
Has the pump suddenly stopped working after working OK for a while? Or Is the motorhome new to you, and you don't know how to switch on the pump?
There's two kinds of pump. A submersible pump goes inside the water tank, at the bottom of the tank with a water pipe and a wire coming out of the top of the tank. An inline pump is outside the tank, usually near the tank, with a pipe from the tank that connects near the bottom of the tank.
There will be a fuse on the distribution/fusebox that protects it. There is often, but not always, a switch on the display panel that switches the pump on/off.
The pump in ours is under the bottom cupboard floor ,to the right of the sink.you have to peel off the cover screw caps ,unscrew 4 screws and take out the floor of the cupboard which is approx 300 mm off the hab floor.
the pump to ours (Y reg) is at the left hand side rear of the water tank.sligtly tucked in behind it.
