seanwinder22
Does anyone know how I would wire the multiplus 12/1600/70 into this nordelectronica mcu-c in the image below ?
I do know the bottom red socket is mains shore power all these sockets have x2 cables running to each socket that then go to a breaker then back out
on the front of this breaker says charger . Space heater . Water heater
I can not find a wiring diagram or manual for it tho
I have also taken a image of the back of the mcu wired in my motorhome which shows the yellow & white cable comes from 1 socket which is the red which is the shore power mains cable definitely I’ve traced this coming in maybe it’s in and out feed
They are the yellow then white cable goes to the wall sockets ? The black cables x2 in another socket which one of them goes to the Victron ip22 I have wired in now it goes to the breaker and back out to the ip22
There’s another socket with x2 black cables which must be for the space heater to the breaker and back out to the heater ?
I’m trying to figure out the ac in and out to get the multiplus wired in
is the yellow power mains coming in for ac out to the multi then the white one for ac in does anyone know ??
I won’t risk trying this I will get help installing if I can not get help here by someone that may have the same mcu?
Also one last question does the ip22 I have installed now need taking out or fine left in for extra charge thank you
