Note: This feature currently requires accessing the site using the built-in Safari browser.
So just to confirm, do the taps have micoswitches or not ?Yes we tried running taps at the same time but no different
It comes from the main tank, we have fitted a new valve, but still only a very slight trickle.
In that case... Somewhere in the pipe ( usually right at the point it joins the pav ) or in the pan its self, there must be a blockage... proly a build up of calcium ( fur )Taps have micro switches and yes you can hear the pump, we have fitted a new pump and a new one way valve, it is a pressurised system. It works the same as before the new valve and all the other new bits, help. It’s the old style cassette toilet.
its either midcro switch or a presurised system unlikley to be bothTaps have micro switches and yes you can hear the pump, we have fitted a new pump and a new one way valve, it is a pressurised system. It works the same as before the new valve and all the other new bits, help. It’s the old style cassette toilet.
they are pressurised using a solenoid valve to deliver the water. To prevent accidents when the cassette is removed, a microswitch/reed switch isolates power to the solenoidits either midcro switch or a presurised system unlikley to be both
I've never come across one like that. Had a caravan and 3 Motorehomes with Thetford loos not had that feature in any of them.To prevent accidents when the cassette is removed, a microswitch/reed switch isolates power to the solenoid
What's wrong with using a spray bottle?We now need to solve this properly as a gallon bottle of water in the toilet to flush really does not cut it.
