HELP WITH OMNIVENT PROBLEM (1 Viewer)
MotorhomersRus
576
270
Barnoldswick
Carthago E Line
Needing some help please with a Omnivent problem.
New to us MH the Fan worked once aware of problems with these on the switch so
Ordered new switch...... still won't work try's then stops lights flash.
If wired direct to power it whirls away like mad :confused:
We have no idea why it would behave like this
so any advice on things to try would be grateful.
TheBig1
17,183
41,167
At a guess, I would say low voltage or a bad connection in the roof
Jan 19, 2014
9,035
23,581
Derbyshire
Elddis Accordo 105
since 2014
Well that was easy.
It's all sealed in clear silicone but looks perfect, no water damage even though it did get wet once. If you hold the fan blade and start it, it trips off exactly the same as the fault with the flashing LEDs so it must be an over current protection which is strange because it doesn't trip off if you slow the motor down with a finger 👆🤔. It's working OK again now so I'll leave it to get worse.
Feb 2, 2015
2,282
7,330
Shropshire, UK
A motorhome!
we are still learning
We replaced our controller and it's been fine since. The controller is £70! Just bare that in mind when it comes to playing up again!
The controller is designed to allow and increase and decrease in current to run the motor at a level to suit . What apparently happens is this Its this bit..that throws a wobbly! Trouble is...its a full replacement and not a repair!
The controller disconnected allows the motor to run full bore forward or reverse. Hence ...no motor fault. The bit that you need to slow the motor down is the controller.
I believe there is a fix for this without the controller?
I believe you can put a switch on board that allows (Through diodes added ) an increase or decrease in motor speed?
Check out the thread with Riverbank annie and DBK . Im sure they have dealt with this before?
Kev
Jan 19, 2014
9,035
23,581
Derbyshire
Elddis Accordo 105
since 2014
I'll make a speed controller for it when it finally gives up. I made one for the home made roof light fans and it works great. It's PWM so efficient 👍
Jan 19, 2014
9,035
23,581
Derbyshire
Elddis Accordo 105
since 2014
Right, all fixed. New dc controller module off ebay £6.50.
I put a 100k resistor in series with the pot so it can't be run flat out (the old controller must have had similar, it sounds like it's going to take off at full speed😁)
The hardest bit was making a bit of perspex to cover the hole the old one left.
https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=402336240763
Steve and Denise
5,051
13,161
Spalding LINCS
A Class Carthago
Since 2008
Have you still kept both directions or changed the switch as well. We only tend to use it for extraction so may have to look as this as a mod.👍
I have ordered the bits to do this so will be having a go.
9,035
23,581
Derbyshire
Elddis Accordo 105
since 2014
Took a pic, this is the only way it will go in, I took a tiny 45° bit off the output transistor heat sink with the bench grinder so it went in better, you also have to snap off a little plastic rod thing that sticks down. Would probably look better with black perspex.. Oh well, it works bootiful 👍 😊.
Steve and Denise
5,051
13,161
Spalding LINCS
A Class Carthago
Since 2008
Looks a brilliant job I will post a pic when I’m done might try some white plastic I have a look at what’s about 👍
Jun 8, 2019
4,931
18,789
Bexley Kent
Given up Motorhoming
May 2019
Why not paint it on the inside?
Steve and Denise
5,051
13,161
Spalding LINCS
A Class Carthago
Since 2008
It's much quicker to set the speed too, the buttons sometimes didn't respond with 1 press. If the smoke alarm goes off now it can be on full speed in 1 second 😎 has yours come yet?
Bits arrived yesterday so made a start this afternoon with a bit of luck I’ll finnish it in the morning looks like it will possibly fit in the original grey plastic cover I’ll know tomorrow 🙂
Jan 19, 2014
9,035
23,581
Derbyshire
Elddis Accordo 105
since 2014
On mine there was an thin line on the edge of the circuit board that hadn't been snapped off, only about 2mm but it snapped off easily with pliars. It's tight to get it in the original cover. The old pcb will prize out of it ok 👍
Steve and Denise
5,051
13,161
Spalding LINCS
A Class Carthago
Since 2008
I have trimed everything off at both ends 😂 and it’s looking promising the board fits in no probs, just got to find room for the switch and reostat 🙂
Steve and Denise
5,051
13,161
Spalding LINCS
A Class Carthago
Since 2008
Don't forget the knob may stop the blind shutting if you use it.
Good point I never thought of that lol, but never used it yet, the trimming I have done up to now could easily be put back to standard, the board came straight out giving more room and yes you are talking 0.5 mm here and there as you know but I am optimistic for a fairly good result.
I will get some pics if it works 🤞
Steve and Denise
5,051
13,161
Spalding LINCS
A Class Carthago
Since 2008
Ok here is my version a bit of trimming and cutting and the blind still works I had to remove the old board to make space 🙂
Now back to the step relays 🙄
Jan 19, 2014
9,035
23,581
Derbyshire
Elddis Accordo 105
since 2014
Ok here is my version a bit of trimming and cutting and the blind still works I had to remove the old board to make space 🙂View attachment 431952
Sterling work! 👌
Just a thought, you can get little 3mm LED holders so you could mount the power on LED in the panel next to the switch.
Also did you limit the top speed with a 100k resistor? If you don't it takes about 9 amps on full power and blows the mozzie guards out the top 🤣
Steve and Denise
5,051
13,161
Spalding LINCS
A Class Carthago
Since 2008
Sterling work! 👌
Yes Richard 100k fitted I did consider putting the led in but then thought well if it’s on you can hear it, if I get bored over the winter though it might get done it was a bit tricky getting the board to stay put then fit the cover but a bit of blue tac helped hold it till I got the cover on 👍
Jan 19, 2014
9,035
23,581
Derbyshire
Elddis Accordo 105
since 2014
🤔 Tell you what would look better... You know where the old LEDs used to shine through the front panel, they are like tiny windows, super glue the LED on the inside of one of them, will be discreet and look OEM 😍👌
Aug 11, 2023
3
Cheshire, UK
Bailey Pegasus 534
Since 2021
Hello and thanks for a fascinating thread! Unfortunately the ebay link for the motor controller has expired. Could you post a new link to a suitable one? I am concerned that the Omnivent motor appears to be marked up as 80w, and many of the controllers do not offer that wattage at 12v.
Any help appreciated (y)
Jan 19, 2014
9,035
23,581
Derbyshire
Elddis Accordo 105
since 2014
Think this is the module;
