lucas70
Hi everyone, we are both getting rather fed up with our Frankia as things keep going wrong. Currently when traveling from Scotland to Warrington by Frankia started going into limp mode as the thermostat was getting high then it would return to normal temp and power would return. So after slowly making my way to Warrington I let the motor cool. On checking the header tank I fount it was empty. I refilled and ran the engine for an hour, I couldn’t see any water drips or steam anywhere. The heater was working fine and all seemed ok. As a precaution I checked the engine oil in case ther was water everything ok. However when I got home the header tank level he’d gon from max to min. This happened within 200miles, we had cam belt and water pump replaced when we purchased last September. Would be grateful for any advice. The Moho has a warrenty with NG&B but it doesn’t cover a heater matrix which, I think it might be. I forgot to mention it is a Fiat Ducato 2.8 regards to all Lou
