Help, where is the LH indicator light fuse located.
Oxfordshire
Hymer Exsis I 678
Since 2016
I have a 2019 Hymer Exsis I 678, the left front indicator light has failed. The light in question seems to be both a white day time running light & yellow turn indicator light. I am getting a dash board warning triangle & a message "check LH turn light"
I have looked in both the Fiat & Hymer hand books, but cannot see the fuse identified.
Ok not about the fuse location but is this link any help?
If its anything like my Adria (fiat) it was nothing as simple as a fuse but the ecu? not talking to the indicator, well above my thump it till it works mechanical skill
I think you are correct sounds like the wiring loom troubles a few of us on here have had you either need to repair the loom or purchase new ones and they ain’t cheap😥
You won’t find a fuse specific to the lights it’s the wiring that has cuts in the insulation.😥
If the fuse had blown then all of the indicators would not work. If it is only one then likely that this bulb has blown, or poor contact of the bulb in the holder, or damage to the wire.
I have just had to clean the contacts on my (2007 Hymer) rear indicator bulbs as I had the bulb warning sign come up on the dash. All working ok now.
Thanks to all for your prompt replies. I have read the link /thread sent by Sandral. I am horrified that this has not the subject of a recall.
