Help victron solar charger
Can'tthinkofaname
Don't own one yet
Hello
I've read a few threads and saw comments that people are very helpful here.
I need help with battery settings using a victron solar charger 100/30
I want to charge hankook XV110MF
I haven't got a clue
Looks like a lead acid leisure battery . Default settings should be ok .
Hi thanks for the reply
Yeah lead acid all the victron settings are for their own battery's
None are standard battery's.
Hence my question
I've got a Victron 75/10 solar controller and you can indeed select a standard lead battery in the drop down menu in the settings. See screenshot from the App below. If not available, maybe try a firmware update.
Hence my question
How is a Victron Battery any different to any other lead acid battery ? They are only putting their own Brand name on it !
Select Lead Acid and you will be fine !
I was advised to use the preset Gel Victron discharge (2) for lead acid.
lol that’s very confusing for the end user of the product .
Select a profile for a completely different battery chemistry to the one you are charging . Nice one Victron 😂😂😂
Okay thanks for the replies. There is no setting for a lead acid battery. Hence my question.
I have just taken a picture of the instructions/choices.
So you can see why I'm asking.
Hi yes I have the app but it is the same as the manual, and to me it's useless that's why I'm here asking.
Yes there is. See my screenshot above - "Standard Lead" battery selected from within the settings in the Victron App.
Sorry that's not a choice I have.
I have the choices shown in the manual or I have to edit a preset, which I haven't done because I am not sure of what settings I should use.
Are you using the Victron app with Bluetooth connection?
You will now need to pay £20 to join the forum for further help . This is Extremely good value for money 👍🏻👍🏻
I don't get the standard lead battery option in the drop down list either.
I don't see any lead options in my victron solar presets.
There are 3 different PzS tubular plate traction options, and if my rudimentary chemistry is correct Pz is lead?
This is Victron firmware 1.59 which the app says is current
They are ALL lead acid, some with acid in the gel, some in glass mat, some in water.
Setting no 2 does flooded, that means wet lead acid, if that’s your flavour.
