HELP, problem with water pump in Globecar! (2 Viewers)
Teasy2007
2,086
1,159
Rotherham South Yorkshire
Carthago Malibu PVC
We are just getting ready for our first outing this year and Mike has filled up with water to check the heating and water.
Unfortunately, the taps are on, the water is in but there is no sign of the water pump working.
We have located the fuse, which was blown, and replaced it but still no sign of the water pump kicking into life.
Any advice please???
Ginny
Teasy2007
Teasy2007
2,086
1,159
Carthago Malibu PVC
Thanks Peter, trouble is we cant find the water pump. I was hoping @minxygirl or one of the other Globecar enthusiasts would see the post!!
Neckender
3,221
5,921
Neckend or North Wales.
VW T6.1Kombi day Van
you Need to remove the panel that you move to get to the drain tap and there is a large screwed cover and the pump is at the bottom of the tank.
On the Possle forum I’ve seen pictures of the pump melted, I now carry a spare pump bought from EBay.
John.
Teasy2007
Teasy2007
2,086
1,159
Carthago Malibu PVC
Yes it is in the water tank, so that’s first problem solved. Where did you get your new pump John, and can you give me the exact model please??
Do you think we could exchange it ourselves or is it a job for the professionals?
Ginny
mikebeaches
5,393
8,597
Bristol
Rapido V68 Van Conversion
We've experienced a similar problem with our submersible pump on our Rapido pvc.
Advice from this forum resolved the problem. We unscrewed the top inspection cover for the fresh water tank and reached inside to grasp the pump. Whilst the tap was switched on I banged the pump on the side of the tank to break the airlock that had presumably formed. It worked!
No idea if such action would solve your problem, but it's worth a try. The issue for us arises after the tank has been drained down and the pump dried out.
Teasy2007
Teasy2007
2,086
1,159
Carthago Malibu PVC
This is the pump which is fitted, could this be a replacement, it doesn’t seem very powerful.
32,646
66,532
Sep 10, 2012
2,132
3,709
worcester
Sunliving van
Water pumps are a constant source of problems - just do a search on here.
You won't notice a difference between 19 or 20 ltr.
If you go Reich make sure it will fit through the hole in your tank.
To replace is easy but you will need to expose the electrical connections which may be behind furniture - just depends where the tank is.
Carry a spare - lots of people do - but then I was a boy scout.
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
I would try & stick with the Comet as a replacement. The higher pressure of the Reich could be a recipe for leaks when showering. When you stop the flow with the showerhead trigger, the pump will raise the water pressure in the pipes to 1.4 bar when Globecar were only expecting 1.1 bar. So long as you are happy with how fast the water comes out of the tap, the lower the pressure, the better.
If the fuse has blown, I suspect the pump has seized, rather than it being an airlock issue. Can you hear the pump running when you open a tap? It is possible that a sharp tap may free a lightly seized pump, but less likely. Well worth a try though. But even if you manage to free it off, carry a spare. If it's already seized once, you are almost certainly on borrowed time.
Teasy2007
Teasy2007
2,086
1,159
Carthago Malibu PVC
Well we banged it on the side, still no water but there was a nice smell of burning, so accepted that the pump was broken.
Many thanks to Terry who has recommended a dealer in Barnsley, so we are on our way to pick one up now.
Feb 18, 2018
3,426
11,375
South Ayrshire
Globecar Campscout
Since 2018
We bought a spare identical pump from Amazon. I know some people fit a non submersible pump which may be a route we go down ultimately ...
Teasy2007
Teasy2007
2,086
1,159
Carthago Malibu PVC
Our Globecar is fitted with the Reich pump as standard.
John.
That’s interesting John, Mike has always complained about the strength of the shower - he calls it more of a dribble! Maybe the Comet was put in instead of the Reich. I’ve tried to find which pump was fitted originally but no joy as yet.
We have bought the same comet pump, but if I can find which pump was fitted originally we will buy that as a spare.
17,630
43,256
just a thought, if the old one was giving poor performance it may be wired in reverse. this would match those symptoms plus globecar install a reich pump as standard I believe. both pumps are similar in output and either can be used
german wiring confuses people as they often use blue for live
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
My Campscout dates from 2013. I'd have to go & fish to see exactly what the make & spec of the pump is, but it certainly looks more like the Comet than the Reich. They may well have started fitting the Reich to later models.
Teasy2007
Teasy2007
2,086
1,159
Carthago Malibu PVC
Hi @Teasy2007 our shower and wash hand basin tap hasn’t the same flow rate as the kitchen tap.
John.
Is it weak enough to annoy you as much as Mike?, he complains every time he has a shower!
Having just joined and read the Globecar facebook group this seems to be quite a problem we are considering fitting an external Sureflo to improve flow.
We have also decided that when we drain down we will always take the fuse out so we wont burn the pump out again. Hindsight is a wonderful thing!
Ginny
17,630
43,256
don't keep removing the fuse, as the fuseholder will get loose causing heat and the fuse will keep blowing. surely there is a switch on the control panel to turn off the pump>
Feb 18, 2018
3,426
11,375
South Ayrshire
Globecar Campscout
Since 2018
No, I think you have to fit an in-line switch yourself to do this ... can anyone recommend a suitable switch please as we want to fit this?
32,646
66,532
No switch, when the control panel is turned on so is the power to the pump ... if I work in the camper I've gotta remember to close the taps (open at the mo to prevent frost damage) in order not to burn the pump out so I'm looking at fitting an isolation switch as I forgot about it the other day ... fortunately I was only in there for a few minutes! :rolleyes:
Oct 29, 2008
5,068
5,949
West Yorkshire
Ginny
Does the sureflow use more current? A relay may be required to avoid burning out the tap microswitches.
Garratt
192
358
Miskin
Rapido Dreamer D55+
Since 2017
Wow, no wonder the pumps burn out if the pump is live anytime the panel is switched on. I would make fitting an isolating switch a priority, because when drained down, you’ll be running the pump dry anytime the habitation electrics are on.
By comparison the Rapido/ Dreamer/ Campereve range have a button on the control panel to turn the pump on and off.
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
It's not quite as bad as that. It's a microswitch system rather than pressure sensing. So the pump only runs when a tap is also open.
Neckender
3,221
5,921
I’ve posted before about fitting an isolation switch in the thread Globecar modifications with pictures.
I cut the positive wire to the pump and extended the cut wires through the underbed storage area and in plastic trunking. I fitted the 2 way switch just above the steps to the bed at the side of the bottom wardrobe.
John.
Neckender
3,221
5,921
I’ve found the pictures, here’s what I posted.
The second mod I’ve done is to fit an isolation switch to the water pump because when drained down and taps left open for the colder weather I’ve turned the 12 volt control panel on and the pump as been running dry, now I can isolate the pump.
John.
dfba51bd-585e-4978-9805-e5e0e1d4ba39-jpeg.197354
ce78f9c6-a703-41e2-a53a-02fb0264c26a-jpeg.197355
