Help please... (1 Viewer)
Nomadic Dragon
3
Fiat Weinsberg
2 months
Hi. New to this forum. We purchased a Fiat Weinsberg 2 months ago in Amsterdam. Since then, we’ve been touring Irelandand the UK, now in Belgium. We are headed to Germany soon, then down to Croatia and Spain.
Unfortunately. We found ourselves in a tight spot trying to make a right turn onto a narrow street and scraped the paneling of the outer storage compartment off. The motorized steps were also damaged.
Can anyone provide any information on how I might procure replacement panels or body repair for our Motorhomes?
Thank you!
George
Dec 12, 2010
5,396
21,440
Cumbria
since 2011
A couple of pictures of the damage might help to point you in the right direction ?
Nomadic Dragon
Nomadic Dragon
3
Fiat Weinsberg
2 months
Here is a picture of the damaged area.
The grey panel to the right is similar to what was scraped off the left side, and covering the storage compartment.
Nomadic Dragon
Nomadic Dragon
3
Fiat Weinsberg
2 months
A body shop for the bodywork. For the step, it might just need straightening ?
See if you can find a makers name.
Tried straightening out the steps, but it is of no use. Am looking for body shops that have someone who speaks English.
9,750
20,078
Newcastle under Lyme
Hymer B544 A Class
Since 2015
I think you'll need to speak to Weinsberg to see if they can supply the grey panel and the manufacturer to source the step.
Good luck, not easy to do whilst on the road.
Could you do a temporary repair on the step until your home ? Or use a caravan stepup ?
Much easier to sort when home.
Stonemags76
1,277
3,987
Derbyshire Dales
Auto Sleepers Warwick Duo
Full Time 2011-2013, now part timers!
Just a thought, as I know nothing - would it be worth taping some plastic to the body to stop water getting in meanwhile?
TheBig1
17,575
42,954
assuming you retrieved the broken plastic parts? they can be plastic welded and repaired with fibreglass mat behind
9,750
20,078
Hymer B544 A Class
Since 2015
Gaffer tape is your friend in these situations, if you recovered the trim, tape it on.
If not, make temporary repair to prevent further damage until you get home.
If you are able, remove the step mechanism and either straighten it yourself or take to repair workshop to do. Assuming nothing is obviously broken.
It just might work again if straightened out.
5,396
21,440
Cumbria
since 2011
As others have said, keep hold of the plastic panels and get them plastic welded once you're home. A liberal application of duct tape won't do any harm and a plastic beer crate will do as a temporary step, and you might want to pull the fuse from the step control to stop it operating ?
And really try not to let it spoil the rest of your holiday if you can.
138go
3,276
14,613
Carthago 138
Since 2001
Should have gone to Specsavers ..
Hope you get it fixed. As others have said you need the bits. If not you may have to get the parts from the factory if they have them.
