Help please - cannot remove fresh and grey water tank caps
If you’re really stuck give me a shout and I can help. I’m a plumber, engineer and motorhome owner. Ely is an hour away, if that is where the van is. I’m SG11 p code.
Andy.
That is truly kind of you Andy, thank you very much indeed. They are based in Norwich but I am sure they would be willing to run it over to you if the need arises.
Plastics respond well to heat. Make a poultice of clothes around and on top of the lid, then dribble. boiling water over and keep it wet for a minute or two. This should enable the cap to be removed.
Geoff
Geoff
Thank you very much for your suggestion Geoff. I will share this with my brother in law. My fingers are crossed that one, or perhaps a combination of suggestions will work! 🤞
If you want to try applying heat to it then soak a tea towel, or flannel in hot water. Then heat in microwave, it will get really hot and then apply it directly to item using tongs, or similar.
Thanks again Andy. donkey Geoff, has just suggested that approach too. Sounds a good option to try before resorting to using tools on the caps.
Small ratchet strap ?
Unfortunately I don’t think so as the only part of the cap that is accessible is the top so to speak. It’s hard to describe but I added a photograph of a similar one to post number 13 on this thread.
Easy to make a tool to remove them, just need a short length of timber with a couple of wood blocks screwed to it.
I see a business opportunity for you to make 3D printed versions to flog to (unsuspecting) funsters! :giggle:
Is it to clean the tank is that the reson you want the top off
Have you tried using a piece of wood as a chisle and some sharp taps to get it moving
Not at this stage. Although I haven’t researched in depth, my initial investigations haven’t found the caps available to buy. It will be my brother in law and sister in law’s decision in the end of course but I think our thoughts were it would be great if they can be released but, if they can’t, then they’d rather not risk breaking them.
That’s right Bill. Of course we understand that it is not essential to do that for cleaning purposes and it was apparent from some of the earlier replies on this thread that some folk never remove them as part of their cleaning routine.
I drink from the tank so we just Milton it then citric acid it once a year
We then use a BRITA filter jug for all our water with no problems for tea coffee
And for me drinking Lyn buy's drinks water
WB
WB
Thank you Bill.
We also drink from the tank and have a Brita filter in the fridge. With my brother and sister in laws new to them motorhome it just seemed prudent, and reassuring, to see the effect of cleaning both tanks by looking inside them if that was possible.
Thank you Bill.
Somtimes it better not to see :rofl::RollEyes:
WB
You might be right there Bill! 🙈🙊
When we had our first proper motorhome we cleaned the tank with a full bottle of Milton drove around for two days
Dumped all the water filed the tank dumped it filed the tank put a kilo of citric acid in it drove around with it for a few days refilled the tank
Invited the mother in law she she always had water with her tables a pint
This was in the morning she was with us all day wasn’t dead by the afternoon.
Water safe to drink
WB
The tank caps one the Hymer Exsis are very easy to overtighten.
But there are no locks or catches - just a rubber seal and a screw thread.
Lenny HB's suggestion in post #21 is as good as any (done that myself)
He also had an Exsis or two - before deserting us to buy his Carthago.
Gentle downward pressure as you turn anti-clockwise. - Simples.
Just be careful not to over tighten them afterwards (or keep the wood handy)
Water safe to drink
WB
Pleased to hear your mother in law survived the process Bill.
Had she succumbed to it at least you would have been able to comfort yourself knowing she passed with the cleanest internal pipes in history! 😀
Thank you for sharing this. I would seem that these ones have indeed been overtightened. Easy to do I guess when one it trying to ensure there will be no leakage via the cap.
It’s good to know there aren’t any locks or catches; we did wonder if we had overlooked something along those lines.
It’s reassuring to know you have had success with the method Lenny Lenny HB suggested. Sounds like Carthago’s gain was Hymer’s loss! 🙂
I made this when I had issues opening the fresh cap on my Rapido, could not of opened it without this, as they were in so darn tight. I leave it in the garage now just in case as it also fits the grey tank. I think others have made better ones now, as this one was 4 years ago but it worked for me
That looks ideal Zac, well done 👏
Hopefully one of the options kindly suggested by the very helpful folk on here will work for us.
I would like to thank everyone who was kind enough to share their feedback, suggestions and solutions on this thread.
I am pleased to say that the “hot cloth” methodology suggested by Andy, Landy Andy and Geoff, donkey has worked! Thank you both very much.
My brother in law and sister in law decided to try that methodology first as it seemed a good place to start and minimise the risk of breaking the caps. They have asked me to add their thanks to mine.
