Help needed please. (1 Viewer)
Catherine MacL
3
Van conversion
I am new
Just bought a Carioca 644 and cant get the electrics to work. Anyone know where I can get a new management system?
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
Have you checked your leisure battery isn't flat? Or how about 240v, does it work then?
Welcome to fun.
Gellyneck
9,214
18,188
Scotland
More than toes wet now!
Apologies if you have but just to check, have you switched on the individual circuits, eg water (tap symbol), etc.......? :unsure:
138go
3,276
14,613
Carthago 138
Since 2001
Why not asked the person you bought it off. Did you see it all working before you bought it. Management systems are not a cheap item. What you are looking at is the control panel. This will be linked to a much larger box of tricks full of relays and electronics. I would try switching everything off first and then let it reset. Make sure the ignition is off.
Which electrics are not working. If it's the 240v ones then you need to be plugged into the mains.
As it was made in Italy it is probably some sort of CBE Panel so might be worth a look round the internet. Now owned by Trigano
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Thank you it seems that the leisure battery just isn't charged enough! Rookie mistake
If the battery has been left in a depleted state for any length of time it will probably be useless and have to be replaced.
MikeD
3,936
3,697
London
IH PVC
Since 2012
An easy one to make. Don't worry about it - we all do it.
You may have lots of questions - don't be shy and post away but as a non member I think you only get 5 posts.
If you are new to the hobby it might be worth the £15 to join.
Anyway - Hi and welcome :D2
